Kenmore elite HE5t quiet pak 9 washer knocks while spinning even empty. with a load it gets very loud but normally completes the washcycle. What part provides stability for the drum?
There is a small arm that contacts a switch in the tub area, When the tub wobbles and strikes it you get an error code OL=overloaded. The arm is bound up and must be lubricated.
Okay the bad news is most likely the bearings in the back of the front load drum are damaged and there may even be some cracking in the back this is causing it not to spin properly it will not be able to work for much longer and if you would need a major repair to fix many cases it is not worth fixing front loader because the average repair cost is around $400 you might want to get it looked at by an appliance professional but most expensive see the links below for more information Replacing the bearings on Kenmore HE3t front load washer Part 1 By How to...
I think possibly your machine is not on a level surface. Try rocking the machine, if it wobbles, the feet need adjusting to level the machine. It will cause damage in the long run if not levelled.
have you tried lower spin speeds? I found with heavy items such as towels and jeans it is best to lower the spin speed. also washing like heavy items on a certain wash cycle is best - i.e. towels on bluky/bedding.
