Question about Dirt Devil Vacuums
I have a Dirt Devil Jaguar bagless vacuum. It used to work great. Now, it is blowing a huge amount of dust out of the front of the machine as I try to vacuum the carpet. can this be remedied?
Posted by sajitgreene on
Roger Potts
  • 694 Answers
This generally happens if the hose system is clogged. No suction so the power head brush just kicks out the dirt and debris you're trying to pick up, and loose stuff that is currently in the hose system. If it has been doing this for quite a while, or has been used with blockage, the motor has to work harder and will eventually burn out, if there is no overheat shut of switch in the cleaner.
Check all parts of the hose system, from the power head to the tank. Clear all clogs. That should take care of the problem.
Another possibility is that the fan blades are broken or worn down. This would result in no suction even though the motor is running.
Posted on Dec 09, 2010
Dust Devil UD40180 repair manuel
Mate I just googled Dust Devil UD40180 repair manual and found this link, I hope it helps... If not then you google Dust Devil UD40180 repair manual It might give you some ideas...CHEERS
http://www.ereplacementparts.com/dirt-devil-ud40180-ultra-vision-turbo-bagless-upright-vacuum-parts-c-36976_37103_37186.html
Mar 12, 2016 | Dirt Devil Ultra Vision Turbo Bagless...
I changed the belt on my dirt devil jaguar and can't get the front wheels back in the right place
Go to this site, scroll down to care tab and you will find the correct procedure.
http://dirtdevil.com/products/details/m085830t/jaguar-bahttp://dirtdevil.com/products/details/m085830t/jaguar-bagless-upright/gless-upright/
Feb 15, 2015 | Dirt Devil Vacuums
Vacuum is spewing dust out of the front vent! We have the Dirt Devil 12 amp bagless upright. Hoses are clear, brushes turn, everything fine except dirt blows OUT instead of going into canister. How
Hi! We actually don't recommend opening the motor compartment. It sounds like there may be a clog somewhere in the vacuum that you are unaware of. Please try following the steps below.
  • Remove the hose from the vacuum from both ends and check it for clogs.
  • Lay your vacuum face down, remove the bottom guard and brush-roll
  • Use a wooden spoon or something similar to help break up and remove any clogs from the lower hose.
  • Check and clean all the filters on the vacuum. If they are really dirty they may need to be replaced.
Hope this helps, if not we can be reached here on Fixya, Facebook.com/dirtdevil or Twitter @DirtDevil
Oct 06, 2014 | Dirt Devil Vacuums
Why is my Dirt Devil Vacuum Hose lacking suction?
I have a Dyson and was having a similar problem some time back. I found out these bagless systems still have a filter that picks up the fine dust to keep it contained. Find out where yours is located and beat the dust out of it really good or just replace it.
Hope this helps.
Mar 10, 2014 | Dirt Devil Vacuums
Dust is blowing out the front vent.
If dirt and dust are blowing out anywhere that they shouldn't be, it's a sure sign that something's plugged farther on up the line. You'll need to disassemble the unit and clear the clog before anything will go through to the dirt cup. Also, as long as you're going to be taking it apart, check all the filters. This is a notoriously neglected part of bagless vacuums, and a very large part of why they start to lose the initial level of vacuum power. Clean the ones you can clean, replace the ones you can't. Walmart and Meijer's are a couple of places where you might find replacements.
Apr 20, 2011 | Dirt Devil Featherlite Bagless Vacuum...
Dust will blow out of the front vent of my Dirt Devil Featherlite Bagless Vacuum. It seems to be shooting out dust that I just vacuum up, but I can't be certain.
Dust blows out of the filter vent is usually caused by a plugged filter drop the filter door on the back, replace or for a temporary fix blow out the filter
Jan 17, 2011 | Dirt Devil Featherlite Bagless Vacuum...
Blowing air out and not vacuuming
This usually means you have a blockage between the roller brush and the bag in the machine. You won't have any suction to pull dirt into the bag. The dirt will fall back onto the roller brush and out the front of the machine.
I hope this helps
Feb 02, 2010 | Dirt Devil Featherlite Bagless Vacuum...
It is blowing dust out of the motor
If this is a bagless machine, then the problem is that the really fine dust that you are picking up from your floor is so small that it is going through the filter and dust cup and building up in your vacuum motor. When enough build up collects, then it starts to blow it out the exhaust. I would bet a paper bagged machine for the long run. They are cleaner,
Nov 28, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
Dirt devil Model # 084590
It sounds like either the bearings are seized, or there is debris in the assembly. You will probably need to dismantle the vacuum and clean everything out. It's not unusual for vacuum s to get really dirty and need periodic maintenance. If you have replaced the belt, then you have the skill to do the rest. Note that after re-assembly don't try to lubricate the bearings. They will only collect dirt faster.
Apr 06, 2009 | Dirt Devil Featherlite Bagless Vacuum...
Blows dust
i had this trouble and it turned out someone in my household had tossed out the filter with the rest of the dirt. you may have lost yours along the way since it's relatively easy to throw out.
Mar 01, 2009 | Dirt Devil Featherlite Bagless Vacuum...
Vacuums Logo
159 people viewed this question
Top Dirt Devil Vacuums Experts
Tim Venetis
Randy Schumann
Randy Schumann
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
