If you only have powered speakers for both mains and monitors, you will NOT use the Speakon outputs on the back.
You will connect USING BALANCED TRS audio cables from the MAIN L and R jacks on the top of the unit to your powered main speakers and also connect the monitor speakers by TRS balanced connections to the MON1 and MON2 1/4 inch jacks on the top deck of the unit.
POWER ALL the speakers AND the mixer from the same receptacle or power source/conditioner.
This may mean running an extension cord alongside your audio snake from the stage. Failure to do do this can cause damage due to exceeding the common mode noise (ground bounce) of different power sources.
Leave the speaker slide switch in the Main L/R.
Adjust the rotary knobs for Mon1 and MON2 for each channel to proportion each to the monitor "mixes" which you will control overall with the MON1 and MON2 sliders.
You will use the MAIN slider to control the mains level.
To set the trims for each channel, push the PFL so only that LED illuminate red... then at max inout level for the channel, use the LED bar graph on the right side so it is just a little below the clip level where the top LED's of the bar graph do not illuminate.
