Question about Smeg A2.2 Gas Kitchen Range
Replacing the original oven selector switch (8 terminals) with new component part (11 terminals) as recommended by Smeg distributor - what is the correct wiring connection sequence? Do I maintain the same sequence of connections ie wire 6 to terminal position 1, wire 3 to terminal position 1a - or is it different for the new component?
Posted by steve_hug802 on
3 Related Answers
ashburton
  • 417 Answers
SOURCE: How to wire SMEG Oven SA9066CER
Yes that sounds o.k
Posted on Nov 30, 2008
Anonymous
  • 43 Answers
SOURCE: wiring problem
If they only way to fit your cable is by using the terminal push on connector (which, frankly, i'm not 100% sure what that's describing) and you can easily get that from your hardware store then yes, as long as you can connect up your wires without difficult and without stray copper.
Red wire is live, but white may be live as well during one aspect of operation. Usually neutral is black or blue. If your cable has red white and blue color in it then your using a 3 phase cable. A single phase 3 core cable will have red/brown black/blue green/greenyellow.
Hope this helps. Let me know.
John
Posted on May 09, 2009
barterjoe
Joseph Mueller
  • 346 Answers
SOURCE: can anyone supply a wiring
Looking at http://www.smeg-service.co.uk/support/index.php I have come to the conclusion that the best wat to have this problem resolved is to post it to the help forum or hire an engineer. Smeg has locked down any drawings. Take some pics and draw the wires and you might get someone to figure it out for you. Always remember that the company certified technicians can fix it the right way the first time ;)
Good luck.
Posted on Feb 26, 2011
Smeg oven: UK 80 MFX: Intermittent fault with circular fan element.
either a bad connection on the element terminals or faulty element
Jul 10, 2018 | Smeg Ovens
Hi there, my Smeg WDF12C7-1 washing machine shows up error 11. Please help. Much appreciate.
Smeg washer error code E11 means motor triac short error. The motor control triac is a small component mounted on the controller and is used to switch your motor on and off. Check the mains supply, the main control module and the main drive motor. It is also possible that the part is failing under load and needs replacing.
May 02, 2018 | Smeg Washing Machines
New (graded) smeg scp399x-8 no heat on any of the functions
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Apr 07, 2013 | Smeg Ovens
SMEG OVEN BRAND NEW WON'T HEAT
Sep 08, 2012 | Smeg Ovens
Need to replace my oven selector switch on my bosch oven HBN13M55OB/03
My apologies - I submitted this last night but upon checking for any reply from you, I noticed it had not been posted on the page. I now have to write the entire message again!
Obtaining the part is easy, however fitting it is going to be somewhat more difficult as it's a double oven - meaning it's both higher and heavier. Access for replacing the switch and removing the front panel is from the top so the oven will need to be pulled out from the cabinet or removed. However, the double glass doors make the oven rather front-heavy so it's inclined to topple forward!
This is an expensive appliance and I recommend getting this job done professionally. Should you decide to do the job yourself, you do so at your own risk and you should follow all of the saftey instuctions carefully.
The best - and usually cheapest - place to get any genuine Bosch part is directly from Bosch. They normally deliver in 2-3 working days. The Bosch part number you need is 602732:
http://www.bosch-eshop.com/eshop/bosch/gb/prodlg.htm?Maktx=602732&eshoptype=A&autoselected= £19.63 inc. postage
Click on "Add to Basket" and then "Finish and pay >"
Fitting instructions:
I prefer to do this job with the oven fully removed from the housing but it's probably hardwired to the switch/breaker and needs two people to lift it out. Not removing it also means you have to work at a much greater height, so I recommend complete removal, if possible. The job can be done with the oven only half pulled forward from the cabinet, but the front of the oven needs to be fully supported after pulling it forward or the weight of the doors can (and will) cause it to topple forward.
1. Power off at the breaker/main switch. If you are going to completely remove the oven, you will need to power off at the main fuse box and then remove the oven power cable from the switch.
. Remove the screws which secure the oven to cabinet - these are at the sides and are only visible with the doors open
. Pull the oven control knob off of the fascia panel.
. Remove the oven completely or pull it forward half-way (see above)
5
. Remove the front half of the top panel of the oven. I think it just unclips on these, but there may be a couple of screws to remove at the side first. You will now have access to the switch area.
6
. Make a detailed note of how all the wires are attached to the main oven switch. It's a good idea to take a digital photo for reference. Some of the wires are the same colours so make sure you don't get them mixed up. Also, some of the terminals on the switch are double, so it's best to draw a diagram and give all the terminals numbers and record which wire goes to each one.
7
. Detach all,the wires from the oven selector switch. There is another white "box" attached to the back of the switch, but you don't need to disconnect the wires from this. This box is the thermostat which is attached to the temperature probe in the oven with a long wire.
8
. Remove the screws securing the selector switch to the oven and detach the switch. Make note of how all the parts - switch / bracket / support, etc - fit together. Another digital photo may be useful here.
9
. Unscrew and pull the thermostat out from the back of the selector switch. You should now be able to remove the switch from the oven.
10
. Assemble the new selector switch with the bracket, support, thermostat, etc and secure it to the oven.
11
. Refit everything else in reverse order of the above.
This may be a little bit more complicated than you were expecting. If you don't feel confident to do the work yourself, then please seek professional help. If you do decide to DIY and you let me know when you are planning to do it, I can try to be online to assist you if you get stuck anywhere.
Merry Christmas!
BElectric
Dec 18, 2010 | Bosch Ovens
Rear circular element not working
more often the element burns out before the selector switch. If there is an indicator lamp that illuminates when you turn it on and the light isn't coming on then it could be the switch.
Apr 28, 2009 | Smeg SUK61MFX Gas Kitchen Range
SMEG SUK62 MFX
check stat is not open circuit and check selector switch not damaged
Oct 18, 2008 | Smeg SE250XUK Stainless Steel Electric...
Hi, I have a Smeg Oven SA410X and the oven over heats everything. The temp goes to high every time even though I set it lower. Do I need to get the thermostat fixed?
it is quite possible the stat needs replacing.
what is also worth a check is that the stat is still in position on the back of the selector switch. the stat is clipped onto the back of the switch and can come away
Oct 15, 2008 | Kitchen Ranges
Smeg A2.2 Gas Kitchen Range Logo
183 people viewed this question
Top Smeg Kitchen Ranges Experts
Michael Thomas
Michael Thomas
Lee Hodgson
Lee Hodgson
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
