Koss HD 50 Computer Speakers Logo
Question about Koss HD 50 Computer Speakers
Wiring diagram fot Koss HD-50
1 Related Answer
Open SKy
Carlos L. Burgos
  • 620 Answers
SOURCE: Need a wiring diagram for connecting KOSS HD 50 COmputer speakers
Hello there! lellya
First,
1) you have to tell , what kind of sound card you got? on board audio? A7, or Creative Audigy? 5.1 or regular.
2) then, you have to connect one speaker to the other, one two way connector cable, for the 2 KOSS speakers.
3) another cable that goes in back of your koss and from the out of your KOSS Speakers to the input of your sound card, at back of your PC, this input is your sound card jack.
4) its supose to work like so.
good luck
Posted on Oct 17, 2008
I need a wiring diagram fot tata Indica 1.4 petrol lsi
Did you ever find a wiring diagram for the tata indica 1.4 petrol lsi? I am looking for the diagram as well!
Have Koss hd-50 (hand me down) would like a diagram, have no sound, running winxp on dell xperion 8400, says "no active mixer devices"
i will go through the process of setting up sound on your computer
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
if you need more help with this post a reply
hope this helps you
1helpful
Hello everyone! I have lost my Koss HD50 power supply and was wondering again, how many volts and how many amps? ex:6V, 500ma Thank you kindly! Erjel
Three C cell size batteries per speaker is what you use if you are on the go.
http://www.shopping.com/Koss-HD-50/the-paradox-decent-small-computer-speakers/1386310/reviews#tabAnchor
Hmmm.
EACH C cell battery produces 1.5 Volts (DC)
3 times 1.5 Volts (DC) = 4.5 Volts
Total of 9 Volts (DC)
500 MilliAmps?
Your main concern is with the Voltage.
The Amperage can vary. It can be more than needed.
Why?
Because Amperage represents Current.
How much Current is available.
(Water hose example;
Voltage is the speed, or velocity of the water coming out. Amperage is how many gallons per minute that comes out of the hose)
However, you better make sure that EACH speaker receives No more than 4.5 Volts (DC)
Since you do not have the special splitter adapter cord that comes with the power brick, you will have ensure that EACH speaker receives no more than 4.5 volts.
This is if you are trying to use a 9 Volt (DC) power supply. (AC adapter)
Please post additional questions in a Comment.
Regards,
joecoolvette
My GD-50 KOSS SPEAKERS HAVE NO SOUND AN THEY ARE PLUGED IN
you need an external sound card. plug into your pc or laptop then plug in your speakers , hey presto. prob solved. and cheaply to.
Repairing crossover
I have the Koss-original wiring diagram for the CM/1030 - both the "old" and "new" versions. Contact me at [email protected]. Jeff Mackwood
2answers
Wiring diagram
If you have a computer try the web.
...i lost my installer..
check Koss web site for the driver
Hello there! lellya
First,
good luck
4helpful
Speakers set up properly, but no sound from PC
I have set up Koss desktop speakers properly (I think) -- they are plugged into the power outlet, plugged into each other, and plugged into the CPU of my computer. But there is no sound at all coming out -- just silence.Can You Please Help Me
Top Koss Audio Players & Recorders Experts
Steven Wander
Steven Wander
Marvin
Marvin
 Grubhead
Grubhead
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
