Question about Bunn CWTF15-TC
What size coffee filters does the Bunn CW take?
Posted by blue01bullit on
5 Related Answers
Gord Thurston
  • 131 Answers
SOURCE: WATER NOT HOT
This is caused by one of three things - either your limit high limit thermostat is gone, your thermostat is sticky, or your element died. Try turning your thermostat up or down a little bit. if your thermostat is stuck, this will usually start it again. Look for any burnt wires as well, because sometimes they will burn off of a contact.
Posted on Feb 12, 2009
EsWorld
Ernest R
  • 1618 Answers
SOURCE: The Bunn CW Series overflows the pot. How canwe
Open the front panel, there is a set of instructions on it, you will have to make sure the board is set to program and not lock, before you adjust.
Posted on Aug 14, 2009
Anonymous
  • 40 Answers
SOURCE: Filter basket overflows after cleaning Bunn VPR Coffee Maker
Make sure you are using BUNN brand cupcake filters, not the shorter-sided generic variety. Also, inquire with BUNN about an optional attachment for some models that will slow down the rate of water flow. Lastly, ensure that you are not over-filling the basket with grinds. There is an upper limit to how much a coffeemaker will hold, and some people try to compensate for weak coffee by adding too much.
Posted on Feb 16, 2010
Gord Thurston
  • 131 Answers
SOURCE: my gr10w bunn coffee maker leaks while using.I
If it is leaking out past the filter basket, it can be fron two things- either the basket edges are worn out, and is allowing water to leak past it, or the hole is being partially blocked by scale or caked coffee. in the first case, try replacing the filter basket. In the second case, you can either clean out thr hole or try running a drill bit through it to clear the hole.
Posted on Apr 23, 2010
EsWorld
Ernest R
  • 1618 Answers
SOURCE: I have a BUNN CW series coffee machine at work.
Descale the tank and replace the water filter on the coffee brewer inlet line.
Posted on May 07, 2010
Bunn CW Coffee Brewer not brewing enough coffee - amount is half
Have you cleaned lately, put in an empty filter and fill with cold water with a tablespoon of white/clear vinegar. Run the brew cycle, empty pot and while still worm fill with cold water again with out vinegar. Than check filter to see how much hard water chunks are in the filter. Repeat with and without vinegar tell filter is clean. One question though is there a lot of steam coming out of the top during the brewing cycle if so inside there is a tube that may be cracked, broken or came loose, have to look inside. requires opening or disassembling unit to check. REMEMBER when taking apart UNPLUG unit first.
Nov 17, 2015 | Bunn CW Aps Single Airpot Coffee Brewer,...
Filter holder bracket is broken. where can I get another?
Hello Doug,
I am giving a link to a site, that is popular and very well known. Even if you do not find your filter holder bracket on there list, there is a contact number as well as you can talk live chat to ask them to get it. I am sure you can find the part you need here. Even though yours is a NHB, you can ask them if the NHBX will work, if they do not have the NHB... Thanks Mike
http://www.cw-usa.com/parts-bunn.html?gclid=CNnYge-59asCFQdShwodlG_J-g#product_listing=%3Fcurrent_page%3D1%26results_per_page%3D10%26order_by%3Dmost_popular%26search_params%3DCategory_DELIMITER_id%3A131%3A%3AProductTypeAttribute_DELIMITER_custom_product%3AFilter%2520Baskets%26search%3Dtrue
Oct 19, 2011 | Bunn NHB Coffee Maker
Aug 14, 2009 | Bunn NHB Coffee Maker
I Have a new Bunn CW15-APS and am trying to make it produce stronger coffee. How do you adjust coffee strength since this system is so automatic?
To get stronger coffee, I would advice adding more coffee to the brew basket or using a slightly finer grind.
Jul 18, 2009 | Bunn CW 15-APS Coffee Maker
On-Off light not working
My coffee maker is about 15 years old. The on and off switch works but the light does not. Is there a way to replace the bulb.
Than You
Judith 54
Sep 08, 2008 | Bunn NHB Coffee Maker
Bunn CWTF15-TC Logo
589 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
