SOURCE: Chrono hands
Please make sure that you have replaced your battery properly.I suggest you t reinstall it once again.
Let me know the result
SOURCE: Tag Heuer Link, stopwatch seconds hand stops 2 seconds before 12
Pull crown out to position 2 [in between unscrewed (1) and pulled all the way out (3)]. Tap Button B (bottom) to reset by step back to zero.
Incidentally, Button A works Hours register in same manner for position 2. You can similarly reset second and 1/10th with Buttons A and B, respectively, while in position 3. Cheers!
SOURCE: Tag Heuer CA 1211-RO Min. Hand resets to 59 Min.
Unscrew the crown and pull out halfway. Use the stopwatch buttons to advance the hand to where you want it. Then push the crown back in and screw it down. You may need to pull the crown out all the way--I cannot recall which setting controls the minute hand and which the hour hand on the stopwatch function. This has to be done every time the battery is changed.
SOURCE: my tag heuer carrera stop watch doesnt reset
Try this.
Pull the winder out fully. Then press the top right chronograph button to move the centre seconds hand on. Then push the winder back in.
on some models you should only pull the winder half way out.
good luck
SOURCE: I have a tag link automatic CJF2112 and the
Hello
Get this U-Tube link, where all adjustments to your watch has been show. If you need any further assistance, contact the nearest Tag Heuer service center at your town. No user repairable options left with this device.
www.youtube.com/watch?v=alnkRZDHams
OK
