Question about Mag Innovision LT982s 19" Flat Panel LCD Monitor
Need a Mag lt982s users manual - Mag Innovision LT982s 19" Flat Panel LCD Monitor
Posted by Mary Riley on
5 Related Answers
Benimur
Louie Role
  • 6966 Answers
SOURCE: Mag Monitor LT982s model900p
Hi, Try this link http://www.pchub.com/uph/category/43/LCD-Inverter.html In some instances inverters for other brand/model will also work for your Mag. You just have to match the part number. Good luck and kind regards.
Posted on Oct 02, 2007
Benimur
Louie Role
  • 6966 Answers
SOURCE: MAG Lt982s
Hi all,
Below is a re-post of my response to similar issues.
...Based on your post/description, I will initially suspect the inverter and/or the CCF Lamps since as you posted "dim screen picture" indicating that the backlight(s) are defective and/or the inverter is not supplying (sufficient) powere to the lamps.
If the unit is relatively new and under warranty, it may be to your advantage to have it replaced or seek the services of their Service Center. Should you want to do a DIY, it would be required that you be familiar with electronic circuitry and components, use of a DVM and a soldering iron and access to a service manual or at least a schematic diagram.
Incidentally, there are known cases where similar issues could be resolved if you try lowering your display properties (resolution and refresh rates) but that would also include the powerlight changing colors.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Thank you for using FixYa.
Posted on Mar 10, 2008
Anonymous
  • 50 Answers
SOURCE: need driver and users manual for mag innovision lt576c monitor
Download updated drivers and manual from Mag website link here: http://www.maginnovision.com/Support/Downloads.aspx where you select product group, type and model.
Posted on May 25, 2008
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: need a driver and users manual for mag innovisionLT576s
+1-800-776-8439 to request manual/troubleshooting for this product - the manual is no longer available online
Posted on May 26, 2008
Anonymous
SOURCE: Mag Innovision LT982s 19 in
yes the power supply or capacitors are shot. the part u want is from proview technology inc
attn: parts dept.
7373 hunt ave
garden grove,CA 92841
it is the lcd power supply, P/N 860-ALZ-M713W-f
F0742683G
1-800-776-8439 follow prompts....ed
Posted on Feb 10, 2009
I have a mag innovation flat screen computer monitor but I need the power cord for the monitor it is a LT717S model # 700P made in 2006
The power lead you need for this monitor is a standard EU 3 pin. you can purchase these from any good electrical or computer store.
The look like the old Kettle plugs if its of any help
Jul 24, 2010 | Mag Innovision LT982s 19" Flat Panel LCD...
How to download a owners manual for MAG Innovision LT717s LCD Computer Manual
I solved the problem myself by going to the homepage of MAG Innovision and i downloaded the manual i needed from there...Thank you.
Oct 29, 2009 | Mag Innovision LT982s 19" Flat Panel LCD...
No sound from the monitor
Go to control panel and find volume sound and put the WAVE up on line.
Vitally
Jun 02, 2009 | Mag Innovision LT982s 19" Flat Panel LCD...
Mag lt982s no green light no power at all
try testing it in another outlet a known good outlet if it powers on then your outlets bad if it doesnt means a bad cord or bad monitor
Feb 10, 2009 | Mag Innovision LT982s 19" Flat Panel LCD...
Do i need a new video card
Hey mate,
You can download the driver for the LT982s here:
http://members.driverguide.com/ums/index.php?action=lch&driverid=489582&furl=aHR0cDovL21lbWJlcnMuZHJpdmVyZ3VpZGUuY29tL2RyaXZlci9kZXRhaWwucGhwPyZkcml2ZXJpZD00ODk1ODImYWN0aW9uPWRvd25sb2FkdGFi
Choose 'Download the file by watching a series of Ads, and just press'Skip' underneath the adverts for 7 pages, and then enter the 3-lettercode and download to your hard drive.
If it's a zip file you'll have to unzip it to a folder. If it's an .exefile just run it and reboot. If it is not, then go to Control Panel,System, Device Manager, and click on the + sign next to Monitors, anddouble click the device. Then click the Driver tab and Update Driver orInstall Driver, and choose the 'Let me find' manual search option, andnavigate to the folder you unzipped it to. Double click on the driverand press Install. Then a reboot will complete the installation.
Good Luck and Season's Greetings to you!
Chris (ziraffa)
Nov 18, 2008 | Mag Innovision LT982s 19" Flat Panel LCD...
Mag Innovision LT982s screen problem
Based on your post/description, I will initially suspect the inverter and/or the CCF Lamps since as you posted "dim screen picture" indicating that there is ** backlight(s) and/or it is **t receiving power from the inverter.
Incidentally, there are k**wn cases where similar issues could be resolved if you try lowering your display properties (resolution and refresh rates) but that would also include the powerlight changing colors.
Mar 09, 2008 | Mag Innovision LT982s 19" Flat Panel LCD...
MAG Lt982s
Hi all,
Dec 11, 2007 | Mag Innovision LT982s 19" Flat Panel LCD...
Oct 02, 2007 | Mag Innovision LT982s 19" Flat Panel LCD...
Open Questions:
Mag Innovision LT982s 19" Flat Panel LCD Monitor Logo
44 people viewed this question
Top Mag Innovision Computers & Internet Experts
ThaMp3Doctor
ThaMp3Doctor
Joe Goldman
Joe Goldman
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
