I have not repaired this particular model. If this TV is a projection set,you have one of two possible problems. First....You may have convergence IC that has lost a ground contact to the signal board. We are discussing the board that has all your RCA connections and RF connectors. You may have to replace, possibly a STK-XXX series convergence IC. One or two capacitors near this IC, usually a bad cap will end the life of an IC and resistors. And replace a couple of resistors, these are standing tall next to the convergence IC. The next problem could be on the power supply. The power supply will almost always have the flyback transformer on it. If you can locate the vertical IC..This IC may need resoldering. You will see rings around the pins of the vertical IC. Replace the three or four capacitors next to the IC. A bad capacitor will overheat an IC and cause solder grounds to separate. Thanks for asking and show a few hands of support!
