Question about KitchenAid KEMC377K Convection / Microwave Oven
Microwave is running sounds like it is heating but it isn't. also door seems like the spring came off to make the door close easier
Posted by vended on
Norm Dickerson
  • 291 Answers
This is a very complex repair, and should only be done by a technician that has worked on these a lot. The heating problem can be wiring, magnetron, safety thermostats, high voltage diode, transformer, capacitor, or control board. Out of all the brands and models we work on this is one of the toughest to work on because of the amount of labor you have to put into it, to get into the unit to diagnose this type of problem. I would recommend that you use one of whirlpools warrantee companies, as they will probably have the most experience with this model. Good Luck, Appliance Specialists.
Posted on Dec 09, 2010
Bosch integrated microwave doesnt start/close
Door latch settings are out because door slamming and abuse of unit
Dec 02, 2013 | Bosch Microwave Ovens
Microwave keeps running with door open
I'd say the door interlock switch has failed, and supplies a connection when it should not. Microwave ovens can be dangerous to anyone poking around inside, even when unplugged, so get a quote from a service tech. You might find that parts+labour is almost as much as a new one.
Microwave radiation being released through an open door is also a hazard, as it is known to cause eye cataracts, so don't get near if the oven does this.
Nov 19, 2013 | Panasonic Inverter Countertop Microwave
I have to press up on the door to make it heat
Rich,
It sounds like there is an issue with the interlock latch or switch that allows the inverter to operate. Check the following:
The door hinges to be sure they aren't loose, misaligned or bent.
Check the latch on the door to be sure it engages the cam inside the main unit solidly and that there isn't any play in the door. Also check the door gasket to make sure it isn't preventing the door from closing properly. Since you said the unit was over the stove, things can become misaligned from the stovetop heat.
You may be able to able to fix this, but it may require partial disassmebly of the microwave. If you are unfamiliar with this type of service, it's best left to a trained service tech.
You should disconnect the power before attempting any repairs.
Aug 18, 2012 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Sometimes when I go to heat something in the microwave it doesn't heat but when I open the door and then close it it sometimes will work?
Sounds like the door switch is going bad this is the switch that "tells" the microwave the door is closed so that way it doesn't run with it open
Apr 26, 2011 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Can not open the door in microwave the release button springs seem to not working can that be fixed. Have opened the release button but cannot see the problem
Do not pry the door open since there is an easier remedy which will lead you in the direction that you need to fix your problem. Take the cover off after you disconnect the power to it. Once you have taken the cover off (only a few screws) you will be able to see the two latches that hold the door closed and the link that opens both of them. You can just lift both latches at the same time and it will open. After you have done that take a good look and press in on the open door button and you will see where you have the problem of the door hanging. That button should push a linkage that pushes up on both latches at once to open the door. It is spring loaded so that it comes back down so that when you close the door it will hold the door close.You need to take the cover off the microwave so that you can pull both of the latches that hold the door closed up. When you push the button in it engages a linkage that pushes both taches up at the same time to open the door. It is springloaded and will come back down during normal operation to hold the door closed when you close it again. That area is where your problem is. By looking at what happens when you press the open door button you should be able to readily see where the problem lies in that linkage
Feb 12, 2011 | Sharp R-1610 Microwave Oven
Seems to be working but does not heat up.
This means the Magnetron (this is the part that heats the food) has broken especially if everything else works as usual. Generally it is not work replacing the part as it is almost as cheap to just buy a new microwave since it is the most crucial part of the microwave. You can find the replacement part at repairclinic.com, just enter the model number of your microwave to find the right part. My recommendation is to just replace the microwave as it will be much easier and the new one will be less likely to break sooner.
Let me know how this works out for you.
Benjamin
Jan 23, 2010 | Sanyo EM-V5405SW 1200 Watts Microwave Oven
Microwave seems to run, but won't heat.
We have a similar problem! It sounds like a problem with the microswitch inside the unit that the door is suppose to engage when closed. If not engaged properly, it will not cook. We had the switch replaced last March but it has started acting up again. We can press in on the door and/or lift it slightly and it will cook. Try putting time on the counter and hit start. It the word "cook" appears then try moving the door slightly and see if the turntable starts turning. If not, then you may have a more serious problem. Good luck!
Oct 09, 2009 | Frigidaire FMV156DC Microwave Oven
KitchenAid KEMC377K Convection / Microwave Oven Logo
70 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
