Question about Kodak i1220 Pass-Through Scanner
I scanned one size of a page. Why I got the result is two pages including 1 page with content and one page is blank. How can I fix this?
Posted by tudtc on
Anonymous
    New Friend:
  • 3 Answers
Tell your scanning software to only scan the front of the page. The i1220 can scan both sides of the page with a single pass. That's what its doing (the blank page is the back of your scan).
Posted on Jan 09, 2011
How to turn off safe search on google
Turn SafeSearch on or off
  1. Visit the Search Settings page at www.google.com/preferences.
  2. In the "SafeSearch filters" section:
    • Turn on SafeSearch by checking the box beside "Filter explicit results." Turning SafeSearch will filter ******** explicit video and images from Google Search result pages, as well as results that might link to explicit content.
    • Turn off SafeSearch by leaving the box unchecked. With SafeSearch off, we'll provide the most relevant results for your search and may include explicit content when you search for it.
  3. Click the snp_1d4ffc456d1c37c30575a5430697df68451c_3186894_en_v5 Save button at the bottom of the page.
Source:
https://support.google.com/websearch/answer/510?p=settings_safesearch&hl=en
Dec 12, 2013 | Computers & Internet
My printer -X1185 prints the page with a 3 inch blank area on the left side and some of the right side printing is off the page. This is typical in my e mail page, and even if I center the letter on...
Web site designers create Web pages for display on a monitor, not for users to print on 8.5- x 11-inch pieces of paper. This becomes obvious the first time you try to print a Web page. Content you need may get chopped off by the right printer margin, whereas content you don’t need, such as the site’s copyright information, will print on its own sheet of paper. Fortunately, you can avoid such problems with a little foresight.
Before printing any Web page, open Internet Explorer’s File menu and select Print Preview. The current Web page will appear on-screen exactly as it will print on paper. Scan the preview carefully. If it appears that some content is chopped off by the right margin, click the Page Setup button located directly to the right of the Print button in the upper-left corner of the Print Preview window. In the resulting Page Setup dialog box, adjust the left and right margins so that each is set to 0.25 inches. The extra inch of space you gain by resetting the margins should provide just enough room to accommodate all of the content on most sites. Click OK to save the changes and return to the Print Preview window.
Next, scan the preview to determine which pages contain the content you want to print. Take note of those pages and click the Print button in the upper-left corner of the Print Preview window. Locate the Print Range heading and select the Pages option. Type the number of the first page you want to print in the From field and type the number of the last page you want to print in the To field. For instance, if you want to print just the first three pages of a Web page’s content, type 1 in the From field and type 3 in the To field. If your browser doesn’t have To and From fields, type the range of pages (such as 1-3) in the corresponding field. Make sure your printer has paper and click Print.
May 04, 2008 | Office Equipment & Supplies
I can't scan different document sizes (A3 and A4) in one batch with the Canon 9080C.
IF you are using CapturePerfect 3. version, you can select "Auto detection" for page size, and under 'more' select 'image size' instead of guide plate. Also you may have to select option '1' under user code U10 in case you want to scan pages over 17 inches long. (Press Newfile and Countonly simultaneously, press 'newfile' till you get U10, press 'countonly' and select 1. This will enable scanning upto 1 meter long).
CP3 has "Skip Blank page option", this helps you to automatically delete blank pages on the back side and scan only those with data.
S. Mohan, Chennai, India
Dec 03, 2010 | Canon DR-9080C Path-Through Scanner
When I scan 4x6 photos there is a line (sometimes green) across the entire photo that used to not be there. Scanning larger 8x11 photos the line does not show or when scanning documents. Help! I'm in...
If line is vertical.
Try scanning a bigger document. Use a blank page big as the scan capacity and scan the blank page.
If for example you are using an a3 scanner, scan a blank A3 page.
When scanning blank page set resolution to an high value, so that you does not lose pixels.
Check scan result, and explore the whole document using zoom to see if the line is still present on the test scan of the blank page.
If there is still the line, then it is either a scanner dirty, probably inside glass, or a dafective sensor on CCD sensor array.
If there is no line, then the problem is usually depending on the software.
In that case uninstall the software and install it again.
If that is not enough to fix the problem, try uninstalling software, doing a system restore to a date before the problem started , and then installing software again.
If the line is horizontal , that is usually a loss of power on the high voltage to lamp.
Try reinstalling software first, if that does not fix the problem , and line is horizontal, then it is fault mentioned above.
Horizontal lines at the end of a document may also be caused by faulty scanner control board, or scanner going out of memory.
Oct 10, 2009 | Fujitsu Office Equipment & Supplies
Printer sends out extra page everytime I print
either your paper size settings need to be adjusted in the software, or your setup has included a seperator page.
Jan 27, 2009 | Office Equipment & Supplies
Can only scan simplex or duplex
The scanner can scan in either simplex or duplex mode only. If blank page is scanned, then it will appear BLANK, else someone would say, my scanner is not scanning properly! Remove balnk pages using software or sort on file size and delete the small sized files. Take care to ensure they are really blank.
S. Mohan, India
Nov 20, 2008 | Fujitsu fi-5110C ScanMaker Scanner
Won't scan full page
In the control panel for the scanner, on the bottom left is a button labeled "Specify," where you can adjust how much of the page it scans. Sometimes it is "auto-detect," sometimes it is the size of a small photo, sometimes it is full page. You just have to set it to what you want. Usually auto-detect works, but sometimes it misses and only scans part of a full page, so you have to set it manually to full page.
Apr 15, 2008 | Canon Pixma MP500 All-In-One InkJet...
Displaying white blank page while scanning text/image pages
There is a diagnostics utility for your printer from HP , Please download and test your scanner for problems
http://h10025.www1.hp.com/ewfrf/wc/softwareList?product=297430&lang=en&lc=en&cc=us&dlc=en&os=228
Good Luck
Jan 25, 2008 | HP ScanJet 2400 Flatbed Scanner
Kodak i1220 Pass-Through Scanner Logo
210 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
