Question about Fujitsu Heating & Cooling
We bought a house with Fujitsu Air-conditioners we have no instruction manual on how to use the remote. Im trying to set it to go off after an hour or so. Model No.INDOOR UNIT is, AST12RSJCW Serial No is E001056. The remote control unit model is AR-NJ1. Your assistance would be greatly appreciated. Cindy
Posted by vicncin on
R Subramaniyam Iyer
  • 2,133 Answers
Switch on by pressing ON/OFF. Press mode button to cool position. for cool and keep required temp by clicking
Same procedure for Heat. For heat keep +29 and for cool 25 to 22 degree. Press fan for High, Med,Low. If you keep mode in Auto cool and the fan speed will be low and you can't change fan speed.
Please visit Fujitsu website for further details. Hope my msg is helpful?
Posted on Dec 09, 2010
Hello I need instructions on setting up the timer using the remote control for a RES 24C1 air conditioning unit. Hope you can help. thanks
There are 2 systems in timer set up. You follow as per your remote supports.
1. Set clock first. and then by pressing timer on make the time you need on. and same for off by timer off.
2. Press timer on which starts with 00.00. By pressing you can select how many hours after you want to switch on from current time and same for timer off. Is it useful? Write.
Dec 11, 2010 | Fujitsu 24C1 Air Conditioner
What symbol is for air conditioning?
Here is the operating manual
www.fujitsugeneral.com/.../OwnersManuals/OPManCeilingSuspended.pdf
On Page EN 7 it has the operating instructions for the hand held remote unit. When the word "cool" appears in the display, depending on the temperature that the room is and what the remote is set for, the unit will function in the air conditioning mode.
Nov 28, 2010 | Fujitsu 36CS Air Conditioner
Stuck with vents half open and not responding to remote control
Here is a link to the owner's manual of your Fujitsu 24C1 Air Conditioner. This will help you locate the Manual/Auto Switch on the air handler as well as offer some information on the remote and troubleshooting tips.
Let us know if this was helpful and good luck! :-)
Feb 24, 2010 | Fujitsu 24C1 Air Conditioner
We have a fujitsu reverse cycle air conditioner. Last night when we went to turn it off with the remote it did not respond. We needed to turn it off at the switch outside the house. We replaced the...
Check if the remote control if still good, using the camera of your cellphone point remote control to the cellphone camera and press the "on" button of your remote and you can see the light emitting from your remote control transmitter. If the lights emits that means your remote control is good, if not means the remote control is defective.If the remote control still good try to press the RST or RESET button on your remote control and try. If wont works it means that the reciever board in the indoor unit is defective.
Aug 20, 2008 | Fujitsu Heating & Cooling
Heating & Cooling Logo
570 people viewed this question
Top Fujitsu Heating & Cooling Experts
Marvin
Marvin
Fahr Quad
jdthefixer
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
