Question about Frymaster Dean FM345EETC Deep Fryer
Hi, Frymaster electric fryer. When unit is turned on the right display shows "prob" and it beeps
Posted by highlandoil on
D. Floyd Kolb
  • 43,501 Answers
There is a problem in the system. The problem is usually a sensor that is not reading correctly or not working right.
To troubleshoot this type of problem it is best to call the factory tech. support people and have them walk you through the troubleshooting. then they can also guide you to getting the proper replacement parts. For a problem that is showing up like that you will need OEM parts anyway.
heatman101
Posted on Dec 09, 2010
Anyone know if covers exist for Dean Frymaster deep-fat fryers? I have three in a mobile unit and want to be able to move the trailer without draining the oil.
Hi there!
For open fryers, oil will still spill even with cover during transit because open fryer cover is not designed to contain/ hold oil inside the fry pot to prevent the spill, it is only designed to prevent foreign objects from falling inside the fry pot when not in use, draining the fry pot before moving the trailer from one location to another is only the best solution.
Regards.
May 08, 2012 | Frymaster Dean 2424G Deep Fryer
It keeps beeping and saying help
check the ignition system.controller will display help when burners do not respond during heat start-up or heat demands.also check if the unit receives sufficient fuel for ignition.
Mar 29, 2011 | Frymaster Dean FPH55-2 Deep Fryer
My frymaster just got boiled out. And when we put in the new oil and turned it back on the display said "O-HI" on the left side and "problem" on the right side. What could cause this...
http://www.partstown.com/frymaster/parts#search-tab-content=manuals-and-diagrams
without model number, I can only talk generically. This sounds like the high limit is open and needs to be reset. The partstown website I attached should take you to where you can find your manual and this should help you fix it.
Sep 24, 2017 | Frymaster Dean H17-SC Deep Fryer
Operational Manual
There's a list of manuals for Frymaster units here, yours isn't listed but maybe it's called by another name: http://www.frymaster.com/?xhtml=xhtml/fry/us/en/minisite/service/manuals.html&xsl=minisite.xsl
Feb 20, 2011 | Frymaster Dean H14 Deep Fryer
"PROB" shows when fryer is
Computerboard will display "PROB" error when it could not sense resistance reading from the temperature probe sensor (temperature probe sensor is either open circuit or short circuited). Check first the temperature probe connectors, tighten loosely fitted connectors on wiring harness and computer board, then check if the wires are not damaged. Disconnect the temperature probe and check the resistance using an ohm meter. If the reading is either zero or infinite, you have to replace the temp probe.
Dec 18, 2010 | Pitco Frialator SG14 Deep Fryer
Fryer not starting
I'm suspecting one of the following causes:
1. The thermo couple/thermo pile
2. Gas valve sticking, intermittant operation, doesn't snap open when required all the time. THIS CAN ONLY BE PROVED WITH A MANOMETER and specialized meter that can measure thermocouple or thermoppile current, and volt meter.
I've worked on many a McDonalds Frymaster beeping fryers that intermittantly go into ignition failure that TURNS OUT TO BE THE ACTUAL GAS VALVE FAILING TO SNAP OPEN, and hang only once in a while. Gas valves are only good for so many operations, once that has been reached start failing. The indicator you gave, IT WAS USED BEFORE YOU GOT IT makes me believe it is your gas valve!
ps: manual for your unit
http://www.frymaster.com/docs/uploaded/fry/products/OperationalManuals/819-5887.pdf
Jan 23, 2009 | Frymaster Dean GF14 Deep Fryer
Prob code
THIS SOUNDS LIKE A THERMASTAT PROBLEM!
Dec 08, 2008 | Frymaster Dean EH1721 Deep Fryer
Frymaster fryer mj45eusd
If this is an electric fryer you may have a shorted element that will continue to heat when ever the fryer is turned on,even when it is not calling for heat. If it has 3 phase power, the elements could be wired wrong
Sep 08, 2008 | Frymaster Dean Kitchen Appliances - Others
Frymaster fryer keeps calling for help on electronic keyboard.
There should be some kind of spark sensor usually where the gas line plugs into the pot. There is one wire hooked to it take the sensor out and clean it good. Soot could be building up on it causing it to nolonger sense a flame.
Oct 25, 2006 | Frymaster Dean H22 Deep Fryer
Frymaster Dean FM345EETC Deep Fryer Logo
Top Frymaster Dean Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Paul Carew
Lawrence Oravetz
Are you a Frymaster Dean Kitchen Appliances - Other Expert? Answer questions, earn points and help others
