Question about Uniden Cordless Phone
No problems just need help remenbering ho to program #'s into the phone. Model EXP4540, cordless type
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Uniden Master
  • 102,366 Answers
Follow the instructions on page 7 of this manual.
Posted on Nov 29, 2012
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: How to set up Speed Dial on a Uniden phone?
My Mom had this same problem.   I found these instructions on Uniden's website (uniden.com) under the "Owner Manuel" section.
Here you go - good luck!
Using the Speed Dial Memory
Storing Numbers in Speed Dial Memory
Your cordless phone can store up to ten numbers (up to 20 digits each) in the speed dial
memory. To store number in memory:
1) When the phone is in standby, press [memory]. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number.
 (To enter a 2-second pause between numbers, press [redial/
pause]. Each pause counts as a digit. )
3) Press [memory] again.
4) Select the speed dial location where you would like to store the
number ( [0] to [9] ). You will hear a confirmation tone indicating
that the number has been stored.
NOTE:
• Storing a number to a speed dial location will
overwrite the any previously stored number without
warning.
• When storing numbers into memory and the handset is idle (i.e., no key is
pressed) for more than 0 seconds, it will beep rapidly, and then the phone
will return to standby.
Dialing a Stored Number
1) When the phone is in standby, press [talk], and listen for a dial tone.
2) Press [memory] and enter the speed dial entry ([0] – [9]) that has the stored number
you want to dial. (If you enter a digit that does not contain a stored number, the
handset will beep rapidly, and the phone will not dial.)
Chain Dialing
The speed dial memory is not limited to phone numbers. You can store any number (up
to 20 digits) that you need to enter once your call connects. This is referred to as Chain
Dialing. An example is a frequently refilled prescription number. Store your pharmacy
phone number in one speed dial and your most frequently refilled prescription number
as another speed dial. To use, once you ring your pharmacy's automated prescription
line, simply press [memory] and the speed dial number where you stored your account
number.
Erasing a Stored Number from Memory
1) With the phone in standby, press [memory] twice.
2) Press the number of the speed dial entry. A tone indicates that the stored number is
erased from memory.
Posted on Feb 05, 2009
Anonymous
SOURCE: lucent 7220 cordless phone. I need the sequence for programing #'
386-219-0153
Posted on Mar 28, 2009
Anonymous
SOURCE: need help programming autodial feature on my ge-27923-ge cordless phone
how do you change GE Model 27923 2.4 GHz cordless phone from pulse dial to touch phone dial? I lost my instruction manual Thanks
Posted on Jul 24, 2009
Retrieve messages answering machine
The EXP4540 isn't an answering machine. Please refer to the documentation for whatever answering machine you have.
If you require further assistance, please add a comment to this question and specify the make and model of your answering machine.
Oct 06, 2014 | Uniden EXP4540 2.4 GHz Cordless Phone
Ho to change my message on answer phone
Since you didn't specify the model of your Uniden cordless system, I can only suggest you select it from the list beginning at http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=cordlessphones_mnl to download a copy of the manual.
Sep 24, 2013 | Uniden Cordless Phone
Ho do i get my uniden dect 6.0 cordless phone off of silent mode?
Without knowing the model of your phone I can't give you a definite answer, but on many Uniden phones you switch out of silent mode by pressing and holding the # button.
You can get a manual by selecting the model of your phone from the list beginning at
http://www.uniden.com/owners-manuals/dect-phones/scat/dectphones_mnl/
Jun 21, 2011 | Uniden DECT 6.0 Cordless Phone
I have the new cordless phone and need to know how to put it on do not disturb when away from office. I tried using the *78 as instructed in the quick reference guide but evidently did not do something...
What is the model number of the cordless phone. The DND feature on most 8x8 VoIP extension phones is a pre-programmed soft key on the display.
Please provide me with a little more info on the type of cordless phone you have and I will look it up.
Apr 20, 2011 | 8x8 VoIP Business Phone Service
How do I turn on my speakerphone for my Uniden EXP4540?
Sorry, Uniden EXP4540 2.4 GHz does not have a speaker phone feature. The cordless phone features AutoTalk™ and AutoStandby™. AutoTalk™ allows you to answer a call by just removing the handset from the base so you don't have to waste time pushing buttons. AutoStandby™ allows you to hang up by simply returning the handset to the base. You can check it's manual with this link http://www.uniden.com/pdf/EXP4540om.pdf.
Thanks for using fixya!
Mar 30, 2011 | Uniden EXP4540 2.4 GHz Cordless Phone
Ho do I reset the number of rings
The procedure varies from model to model. Since you neglected to specify the model of your Uniden cordless system I can only suggest you select it from the list beginning here to download a copy of the manual.
Mar 05, 2011 | Uniden Cordless Phone
Need a user/program manual
I recommend that you go to ebay and type in the search section for manual for thomson telecom cordless phone model number ce 21816ge 2-a
May 29, 2009 | Lands Phones
Need help programming autodial feature on my ge-27923-ge cordless phone
Apr 15, 2009 | Lands Phones
Uniden Cordless Phone Logo
Top Uniden Lands Phones Experts
Marvin
Marvin
martin hogg
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
