I found this on another website, most likely it is your power supply capacitors.
Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
when you turn it off your light blinks because your internal fans are still spinning allowing the inside of the chassis to cool off, hence the reason you dont watch a DLP TV and then unplug it. DLP's are JUNK
Something died in there - perhaps a capacitor or a solid state device just blowing and cracking into pieces. happens. Open up the set and see if you can spot it around the power supply area.
there could be two things causing this one there are caps on the dmd module that have failed and the second is the cooling fan may not be running at start and the microprocessor looks for pulse there and that can shut it back down
