Question about Microsoft Xbox 360 Console
So my xbox 360 doesnt want to read the games what should i do?
Posted by nestor761 on
Alex Edoh
  • 943 Answers
There are 3 possibilities here. First being that your game discs may be badly scratched or damaged and thus prevents the console from reading the data on the disc. This is so because the lens of the console is very sensitive to scratches and glitches on discs that are inserted. If this is the problem, you have to clean the surface of the disc with a soft lintless cloth and that should do it. Secondly, it could be a fault from your lens. Your lens might be dirty or might be broken. You should try to get a lens cleaner kit and run it in your console to see if this helps the situation but if it doesnt, that could mean a broken lens that needs replacement. Lastly, the console is usually specific to the type of discs it plays. For example. A disc that is marked for an asian region is most likely not to work on a console that was designed for a european region and if that is the case, you have to go through your console's manual for more info on how to solve this. Hope this helped you? Please rate
Posted on Dec 08, 2010
5 Related Answers
Anonymous
SOURCE: xbox 360 reading games as DVD
you get a ******* life
Posted on Nov 22, 2008
Anonymous
SOURCE: My xbox 360 won't read games. i put in disks just says open tray
The scaner is probobly brocken but you can fix it
Posted on Jun 30, 2009
repairtech99
Rod Sims
  • 767 Answers
SOURCE: My xbox 360 isn't reading the games
Laser is weak , needs new laser
or one of the two motors in
the drive is dead, needs new drive
If you need to replace the drive
you will have to remove the old drives P.C.B
a instal in the new drive.
Posted on Jul 05, 2009
Anonymous
  • 11 Answers
SOURCE: xbox 360 reads open tray and doesn't show game
Just keep closing and opening the tray, sooner or later it should read the disk.
Posted on Dec 05, 2009
Anonymous
  • 11 Answers
SOURCE: xbox 360 will only read dvds shows reading dvd
This means the DVD key went bad. If you flashed your firmware or have a jtag, this is an easy fix, but otherwise I would check craigslist or call Microsoft
Posted on Aug 04, 2010
My x-box 360 doesnt play games but plays cd,dvd
DOes it read to play this game put in a xbox 360 console? If so someone replaced the original dvd drive and didnt flash the firmware or did it wrong. If it doesnt say that then its more then likely a dirty or broken laser. Very cheap part to replace they are on ebay just need to make sure which laser you have before buying one.
Nov 22, 2010 | Microsoft Xbox 360 Console
Well my Xbox 360 will not play any games it says it cannot read the games but the games are barley scratched and then 30 minutes later it finally works. what do i do
nothing can be done i dont think but the xbox might kinda be faulty like it doesnt always work sorry if information doesnt help
Jun 30, 2010 | Microsoft Xbox 360 Console
My xbox 360 doesnt read games movies or dvds but it doesnt have the red ring of death
The laser on the dvd drive is either dirty or bad. Ebay sells replacement for $10-15.
Jun 02, 2010 | Microsoft Xbox 360 Console
My xbox 360 doesnt read my new games how can i fix
Hi, firstly is your xbox still under warranty if so i suggets you send it back to microsoft via going on to xbox,com. on xbox.com you will be able to get help on fixing it firstly, like things to try before sending it off
http://www.xbox.com
if its not under warranty send me a message back and il help you further
good luck
Apr 22, 2010 | Microsoft Xbox 360 Console
Xbox doesnt read games or dvd
If your Xbox 360 is not reading games you need to stop the heat build up getting to the chips on the back of the DVD drive.
To do this use a good Xbox 360 repair guide or send it in.
Feb 03, 2010 | Microsoft Xbox 360 Console
Xbox 360 doesnt read my games
If your Xbox 360 will not play your games this is because of the sensors on the back of the drive overheating it is not normally the laser.
Luckily you can fix this yourself and get back to your games and to do this you need the proven Xbox 360 Repair guide.
Or you can send it in and they will fix it for you the repair will take about 4 weeks.
Jan 25, 2010 | Microsoft Xbox 360 Console
Does not read disc
use a dvd lense cleaner if that doesnt work take it to a game shop it prob the lasor.
Jul 15, 2009 | Microsoft Xbox 360 Console
Xbox 360 doesnt read games but reads dvds
Your laser is bad in the drive. When it comes to reading games, DVd's, music cds, it requires a different strength from the laser in your dvd rom in order to read them. If it can't read all types then the laser is definitely bad and you can either replace just the laser or the whole drive.
Feb 04, 2009 | Microsoft Xbox 360 Console
Does this problem only happen with this disk? If it only happens to that one, then the disk may be dirty or broken.  If it happens to all of your disks, your console's "eye" (disk reading device) may need repair. If this is the case, you should contact 1-800-4MY-XBOX.
Dec 31, 2008 | Microsoft Xbox 360 Console
Game wont start when i put it in
my xbox 360 isnt reading discs and it opens and shuts and still doesnt read the disc
Dec 07, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
32 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
James Bradburn
James Bradburn
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
