Question about Toshiba DKT-2020-SD telephone
How do I forward my phone (DKT-2020-SD) to voicemail?
Posted by hr99764 on
Richard Van Brunt
  • 225 Answers
This does depend on which Toshiba phone system your phone is connected to
Here are a couple possible methods
Press button
Dial 601(all calls) or 602(busy) or 603(no answer) or 604(busy/noanswer)
Dial voicemail access code(extension number of voicemail)
Press button to end
Press button
Dial #601(all calls) or #602(busy) or #603(no answer) or #604(busy/noanswer)
Press button to end
Posted on Dec 08, 2010
Mailbox passcode is uknown. used admisitrative mailbox to reset the pass code. what is the new pass code?
This depends on the voicemail system. Here are some common default passwords for voicemail.
1234
0000
1111
9999
4321
7777
Hope this helps.
Jan 04, 2011 | Toshiba DKT-2020-SD telephone
Deleted main voice mail
you will need to have the admin program and a cable to connect to the system to re-make the mail box 990 or call a forwarded phone and get their voicemail box and press star and log into mail box 999 and create the user 990. If its older and you have a keyboard and monitor simply make mail box 990 and turn on DND.
Jan 22, 2010 | Toshiba DKT2020SD Phone
I have DKT-2010SD toshiba business phone. how can i do a call forwarding for after hours?
There is a couple of way to do this. If you are trying to call forward the lines to a outside extension you will have to press Intercom #6011 9 (your phone number you want it to go to) then redial. Your second option is to get call forwarding through your telephone provider. Usually this is a low cost addition and is the way I would forward calls externally. Hope this helps.
Oct 27, 2009 | Toshiba DKT-2020-SD telephone
Toshiba 2020
If you login to the mailbox change the greeting number from 3 to greeting 1.
Tony
Ameritel
732.477.7733
Aug 27, 2009 | Toshiba DKT-2020 Corded Phone
Reset security code
I need to change the security code to voicemail. I have a toshiba dp5032-sd telephone. Can anyone help me ?
Nov 06, 2008 | Toshiba DKT-2020 Corded Phone
Busy signal
Voice mail is probably got a blown hard drive and we fix that. or it could just use a reset. Turn off and back on or check out your manuals and guides here
http://guides.idacomusa.com/
May 22, 2008 | Toshiba DKT-2020-SD telephone
Call forwarding on Toshiba
Are you tring to Call forward out of the office or into voicemail in house?
Tony
Feb 13, 2008 | Toshiba DKT-2020 Corded Phone
Answering machine
Do you have a verizon voicemail or a in house voicemail?
Tony
Feb 07, 2008 | Toshiba DKT-2020-SD telephone
Toshiba DKT 2020-SD without a manual!
The phone you have DKT2020-SD can be used on many different Toshiba phone systems. For a phone all you will find are user guides. You need to find out which phone system you have and look for the manual for the system. All the Toshiba phone systems say "Toshiba" plus the description on the front cover. Example: "Toshiba Strata DK-280"
Not sure what you plan to change but programming can be quite difficult if you have no experience with it. It does depend a lot on which system you have. Many of the newest systems require special programming software.
Nov 13, 2007 | Toshiba DKT-2020 Corded Phone
Toshiba DKT-2020-SD telephone Logo
745 people viewed this question
Top Toshiba Lands Phones Experts
Marvin
Marvin
Zaid Anarwala
Zaid Anarwala
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
