Question about HTC Touch P3450 Smartphone
Can i use 3g, and gps , live maps - HTC Touch P3450 Smartphone
Posted by mann_maharan on
Anoob Hameed
  • 50 Answers
Unfortunately you cannot use 3G, GPS or live maps on HTC Touch P3450 because it doesnt have the hardware for any of these functions.
Thank you.
Posted on Dec 09, 2010
Can I download fee maps for Ireland and Germany to my Tom Tom Go 60>
Hi Tracy, It depends what model gps and which country you live, I live in Australia and have a life time of maps for Australia and New Zealand and even though I'll probably never go to New Zealand every time I update my maps it automatically updates all. By-the-way a life time of maps is as long as my Navman keeps working... CHEERS..
Mar 31, 2016 | GPS
How can I get free map downloads for my TOM tom live 820 gps
I never registered my life time maps perhaps this is the problem
Feb 19, 2015 | GPS
Im my iphone in map i cannot determint my location so please send me manual solution
Do you have wifi or 3g connection? If you are using GPS, it doesn't require a connection, it relies on the satellites. Try running an application that runs on GPS like N Drive for iPhone because the default maps application requires that you be connected through wifi or 3g.
Mar 05, 2011 | GPS
Hi my iphone is not detecting any gps satellite navigation
Make sure you have the iPhone 3G, or newer, because the original iPhone did not have GPS capabilities.
Also, make sure you are in a open outdoor area, (not crowded with skyscrapers)
Go in Settings > General > Location Services and make sure you have it turned ON, as well as all the other apps in the list underneath.
Make sure your phone is not in airplane mode.
Go in the Maps application and press the compass arrow in the bottom left corner. It should locate you on the map with a blue dot.
Feb 15, 2011 | Apple iPhone 3G
When i use the maps and sat nav on my apple i phone 3g it keeps freezing and taking a long time to load up
I am not sure how to fix that problem but I think that could be your internet slow. You have problem only when use maps and sat nav, those required the internet and GPS thing. If you could test that problem in the wifi environment,then we can see where problem regarding to internet connection issue or GPS receiver issue. From that you might easier find out the solution. Good luck.
Feb 07, 2011 | Apple iPhone 3G
Can i activate gps maps on my instrument htc touch 3g t3232
Friend, You can run maps on any phone. If it has GPS then you will get correct position with the help of satellites and if it does not have a GPS then you will get approximate position with the help of cell communication towers. You must download google maps from www.google.com/maps. That is the most fantastic maps that are available free for almost all phones. The best part is that it has Latitude feature with the help of which you and your friends can keep track of one another on your respective phones. This feature is free too.
May 15, 2010 | HTC Touch™ 3G Cell Phone
How to use gps in iphone 3g apple
simply tap on "maps" on the homescreen to open the Maps application. Then tap on the little circle in the bottom left corner to locate yourself using the gps module.
Out of the box, the iphone 3g doesnt support turn-by-turn directions like your usual tomtom gps system.
You can download apps for that when youre on softwareversion 3.0.
Jul 11, 2009 | Apple iPhone 3G
GPS not working
Try this -
1) Settings > Enable 3G Change to Off.
2) Use the iPhone GPS receiver to locate your position
3) Settings > Enable 3G change to On.
There are two positioning systems in the iPhone 3G, one is the 3G network, and the second is the GPS receiver. The problem occurs when the data from the two systems doesn't match.
Jul 14, 2008 | Apple iPhone 3G
Loading maps updates
Most map providers will advertise that their maps are Garmin compatible - just make sure your provider confirms this.
May 28, 2008 | Garmin Nuvi 660 GPS Receiver
HTC Touch P3450 Smartphone Logo
73 people viewed this question
Top HTC Computers & Internet Experts
Tom Chichester
Rob Woolcock
Rob Woolcock
Marvin
Marvin
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
