Computers & Internet Logo
Posted on Dec 08, 2010
How to erase part of object in order to modify it and also how to apply colour
Ajith Ashok
Level 1:
New Friend:
  • Contributor 34 Answers
  • Posted on Dec 09, 2010
Ajith Ashok
Contributor
Level 1:
New Friend:
Answers
34
Questions
0
Helped
16769
Points
87
If the part is of similar color, then select magic wand tool or magic eraser tool and select the object that you want.
if it is not of similar color, then use magnetic lasso tool to select object and then delete it. then fill the color of your choice.
How do I diagram this sentence-The boy yelled "help" and saw a brave dog quickly run to the rescue.
The is article/adjective modifying subject boy. Yelled and saw are verbs in the predicate of this compound sentence; and is the conjunction. "Help" is the direct object of yelled. A brave dog quickly run to the rescue is a gerund. Subject of gerund is dog with a and brave as modifiers. Run is verb of gerund with quickly the adverb modifying. To the rescue is a prepositional phrase. To is the preposition, rescue the object of to and the a modifier. And here I though my 8th grade talents were no longer needed. Why is this listed in the chainsaw catagory?
Oct 08, 2014 • Garden
I want to know how to save the data in FX9860G calculater
I do not know what you mean exactly by DATA. They might be formulas you want to enter without your teacher knowing about them. In that hypothetical case i wont't answer. Awfully Sorry!
Bu if the data actually refers to numerical values you want to store in lists, matrices or other mathematical objects, the procedure is simple.
Open the object you want to use (list, matrix ,etc.) edit the object to enter or modify the values, click EXE after each entry and press [SHIFT][QUIT] to quit the entry screen.
In the following screen capture I show a 3X3 matrix. (MatA)
As long as the memory is not erased by a hardware RESET or a soft reset and batteries are good, your data will reside in the calculator Memory
1helpful
2answers
How to change the color of my photo in photoshop?
> click selection tool ,enclose the region you want to modify its background colour,choose desire colour from fill colour tool,click the area to fill the colour.
>go to
Edit->Adjustments->Variation
Edit->Adjustments->colour channel mix
Edit->Adjustments->Brightness and contrast
> do your desirable modification and go
and save your modified photo file in the location you want.
Enjoy,Bi....
How do i creat action (making 4 up ) in photoshop7.0? How can i creat an action in photoshop7.0? How can i remove bacgroung of photo in the place of head area (specialy hair cutting)?
There's a few things you ask here and as with all Photoshop processes there are a number of methods to get to your goals.
First up I'll tackle the Erase Background. What you've picked is something quite difficult - removing background around hair. I think maybe the best way for this might be to use the "Magic Eraser" tool, which you'll find by clicking on the Eraser (Rubber, where ever your from) and holding it down where you'll see 3 options (Eraser, Background Eraser, and Magic Eraser). Once you've selected the tool, up the top of the screen there are tool options where you can select the "Tolerance" which is the gammut of colour the picker will select, and select "Contiguous" for selective delete, otherwise it'll delete all that similar colour. If you choose to use the "Background Eraser" you use the same options but you choose a background colour and foreground colour, one is deleted and the other is erased.
the other method for deleting backgrounds is to use the "Magic Wand" and use the same set of Tool Options to set sensitivity with the 'Tolerance' and then once you have selected the area to delete, before you hit the delete button, set a Feather to the selection, this will soften the edges and make the erasure more realistic. (use a small feather of 2 or 3pixels).
OK, Actions. I love actions and use them alot. Once again there's a couple of ways to do this but the 2 easiest are ... with your 'Actions' pallette open, click on the options arrow on the top right corner of the actions pallete and select 'New Action' and Name your action and click "Record" - even though in this instance we are not going to Record the Action. Now go to the Actions Pallette and press the black square 'Stop' button to stop the record process. Go back to the Options pointer in the top right of the Actions pallette and choose "Insert Menu Item" - this will bring up a vaige window about no menu selected, where you go to any of the Menus at the top of the screen and select a menu that will do what you want (such as Filters/Sharpen/Unsharp Mask) and this menu now becomes your action so you either just hit the actions button or use the shortcut you selected before record, to save having to hunt through the menus all the time for regular things you use.
Now, the 2nd method to create and action is very similar - but first, open and image that you'd like to apply the action to and put it in the state you would like the action to start from (ie, if you need to crop or colour or size it first). Now go to your Actions Options and choose 'New Action', name it, apply a shortcut if you want, and hit 'Record'. NOTE that you are now recording and everything you do will be recorded in the action - now go about and do as you would like to the image, colour it, size it, unsharpen it, greyscale it, anything, and all these steps will be recorded. Once you have finished all you want to do to the image, hit the black square 'Stop' record button to end the process and this action is now saved.
Don't forget to go to the Actions pallete Optios and check 'Button Mode' to turn your actions into buttons for one-click instant access.
good luck.
1helpful
Been asked a 1000 times but don't see fix yet
blackhawk92,
No switch but you can see tghe files you want to add to or modify correct? You can copy them to your PC's hard drive and right click over the whole folder or folders and change the properties (uncheck the Read Only radio button) and apply ot to the whole folder or files you wish to modify. You can do this right on the flash drive as well but it is better to have a copy as a backup in case things go wrong which they sometimes do. After it is all done you can erase the drive the same way uncheck the read only status then delete the Hope that ends the contents. Hope that ends the quest for a solution.
randy320sgi
Error Code 5010
This behavior can occur because the Setup program is attempting to locate the Microsoft Exchange System Objects container, but cannot locate it. This behavior can occur because the objectclass attribute that the Setup program is attempting to locate is msExchSystemObjectsContainer. The Setup program then attempts to create an Exchange System Objects container by using the proper class type. However, the object already exists, and a new one cannot be created
To resolve this behavior, rename the organizational unit to something other than "Microsoft Exchange System Objects". To view the objectclass attribute, either use ADSI Edit or LDP. Note that if this organizational unit has the objectclass of msExchSystemObjectsContainer, this organizational unit cannot be renamed.
WARNING: If you use the ADSI Edit snap-in, the LDP utility, or any other LDAP version 3 client, and you incorrectly modify the attributes of Active Directory objects, you can cause serious problems. These problems may require you to reinstall Microsoft Windows 2000 Server, Microsoft Exchange 2000 Server, or both. Microsoft cannot guarantee that problems that occur if you incorrectly modify Active Directory object attributes can be solved. Modify these attributes at your own risk.
Top Adobe Computers & Internet Experts
k24674
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
