Whenever the cooktop lamps blow or when they are removed or installed while the oven has power, the filaments can internally short, causing a surge which can blow the microwave's fuse and damage the circuit board.
I would suggest that you first check and replace the fuse in the oven.
There
should be a "mini-manual" (tech sheet) hidden inside the unit
behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting, testing, and locating
components.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
If replacing the fuse does not restore all functions, we regularly repair these controller assemblies nationwide
by mail for $39.95 postpaid with a one-year guarantee.
The lights can can be
inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly
affect the fan operation or inside light, too.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
