Main Menu select > Services > Data Account
set the current GPRS setting properly.
If you sill not able to figure it out you can get the SMS setting from network service provider and you can save the setting so that settings by default account to you.
To make your GPRS working you should first need the settings for it.You cannot set it.Your network provider should give the default gateway address for it.Then only you can use it.
If you already have set the setting and now if it is not working because the network service provider would have changed the gateway Ip address.
