This is a simple fix in windows vista or windows 7. hit the keys CTRL+ALT+DELETE simultaneously and release. The screen that comes up click on Start Task Manager.
In the task manager window click on Processes Tab. Look for explorer.exe and highlight it and click End Process. Click Yes to stop it. When it is gone from the list, click the Applications tab and click on New Task. In the run box that pops up, type in explorer.exe and click OK or hit Enter. Once your task bar and icons repair look in the system tray area by the clock and the missing icons should now be there.
Press Ctrl + Alt + Delete together and Task manager will be opened. Click on file -> New task . In the box type explorer.exe.a nd click ok. If this doesn't works boot your computer from XP disk and run repair from disk.
Press Ctrl+Alt+Delete when you get to the desktop, when it comes up
click on FILE then on NEW TASK (RUN), type EXPLORER.EXE and press
enter, this should bring your icons and taskbar back.
Once you have
them back, click START then RUN and type SFC /SCANNOW and press enter.
By going into the Task manager, type windows explorer in the new tab. That should bring up your desktop icons, The reason for this could be that you have a lot of applications trying to load all at once and it can cause some lock up in the system.
A full system repair should be your last choice.
Press CTRL+ESC If your taskbar reappears, then
it was just accidentaly been resized and repositioned somewhere IF that doesnt work : press CTRL+ALT+DEL to run task
manager. On the File menu, select New Task
(Run). Type in "explorer" and press OK.
there is something that runs most of the interface between the user and the computer it is called explorer.exe to get the task manager open, you can try pressing CTRL+Shift+Delete another alternative is to do an OS reinstallation.
To get explorer.exe
1) press Ctrl+Alt+Delete; in unsuccessful try Ctrl+****+Delete
2) if task manager opens click on 'New Task..." (if task manager does not open, consider reinstalling your OS or simply don't go into standby/hibernate)
3) Once you get the New Task dialog box, type explorer.exe or C:/Windows/explorer.exe
