Question about DeLonghi PAC C100 Air Conditioner
I have water coming from the back of the unit when it is on, please help
Posted by warren_wilki on
R Subramaniyam Iyer
  • 2,133 Answers
Air filter,Evaporator coil block or less speed of blower motor or drain pan blocked. Hence first service the unit frequently to avoid not only leak of water but also major problem.
Posted on Dec 08, 2010
My water will just stop coming out, it starts out strong but then just slow to nothing, what can i do?
When is the last time you changed your water filter in the unit usually if it were to just slow after coming out quickly it would suggest either the filter needs to be changed due to a build up in the filter you have or you could also have a blockage in your water valve as well which is located on the back side of the unit under the lower panel. If you havent changed the water filter in the unit I would first look at that as being your issue. If you have any questions message me back. Please also remember when our chat has fully concluded to rate how this opinion has helped in your appliance situation. I await your reply
Thank you
Rick
Nov 19, 2011 | Hotpoint HSS25GFP Side by Side...
Water is not turned on at wall, water is coming out of the freezer section from bottom of coils at back. Large ice puddle in bottom of freezer unit. water is continually coming out of the unit with large...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 29, 2011 | Refrigerators
Will not go through rinse cycle. Just hums.
Try putting unit on cold water wash///just to see if cold water is coming in to machine.... You see the rinse cycle uses only cold water the hum you here is most likely cold water valve..to fix turn water of remove water inlet line (cold) clean water inlet screens( there is also screens inside the valves) hook back up turn water on check for leaks test .If this helped you please vote/// need more help please ask....
Feb 02, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
I have a Keurig B66, the reservoir water gets heated but then comes back into the water reservoir from the top vent tube. The water coming back into the reservoir is very hot; almost no water goes into the...
Sorry to read about your problem, I hope this helps you out.
you can contact Keurig at 1-866-901-2739 or Keurig.com
You do have a 1 year warranty, and if you are out of warranty. They will give a discount on a new unit.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
ds
sdf
s
fs
f
Dec 22, 2010 | Keurig B60 Coffee Maker
Help! We bought out home 3 years ago and have a Nortiz tankless water heater. Recently we heard a dripping sound coming from the water heater and found that the bottom of the unit is leaking. We had a...
you will need to explain more of where the leak is on the bottom. You have two plastic valves on the bottom and if the clips are not on exactly it will leak and if the person who replaced valves did not use vasoline when they put it back together the could have cut the gasket ring on the inside putting in back together and again it will leak. You have to determine where the leak is coming from to begin with using a flash light to get the exact location. .
Oct 05, 2010 | Noritz 6.9 Gallon Residential Direct Vent...
All of a sudden the airconditioner started filling up with water and the fan blades started spraying water out of where the air comes out. The unit is draining from the back.
Try cleaning out from under The evaporator (front) coils towards the back so the water can drain underneath the front coils towards the back
Make sure the unit is tilted a little towards the back
Clean drain hole in back too.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
[email protected]
Aug 23, 2010 | Kenmore 75050 Wall/Window Air Conditioner
I HAVE THE SAMSUNG DISHWASHER dms300trs AND IT SHOWS F3 ERROR ???
Have the same problem with brand new, unused DMS500TR dishwasher. Rang Samsung, they said F3 is a water leak error.
Aug 19, 2010 | Dishwashers
My bosch dishwasher check water light has come on and the water has stopped circulating round
check your fill hose. thats the water coming into unit . if its not that then your water valve is bad. unit is not receiving water. if this helps you please send me a 4 thumbs uo post
Feb 22, 2010 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
APE08AK GE Portable Room Air Conditioner isn't draining
I had the same problem and unscrewed and removed the back cover (AFTER I UNPLUGED THE UNIT) and noticed there is a small black tube that the drain tube connects to. Mine was broken off track and I had to physically remove the small black tube, put it back in it's place and super glued new tabs along the side so it would tilk back and drain the water in the bucket vs. the floor via the unit.
Hope this helps.
May 25, 2008 | GE APH10AA Air Conditioner
DeLonghi PAC C100 Air Conditioner Logo
324 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Sheldon Dedek
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
