SOURCE: Vtech phones loosing connection to base
You are pretty close to the solution. The problem is the charge detection in the handset. All handsets on a cordless phone detect the battery level with an hexadecimal value in the memory. Each hex value equal a volt value of the battery. EX: 3.5v = 9B
3.6v = 9C 3.7v =9D etc... The problem is the hex value in your defective handset are all mess up. So 9B is not 3.5v anymore. Then your handset could last 1hr after foul charge or doesn't alert you before the phone goes dead due to low BAtt.
SOURCE: Problems with C110 & A110 Vtech Mirage Dect Home phones
Have strangely got the same problem - about the same time you posted this, but intermitently. I have isolated that the problem is in fact the handset itself, not the base unit. I eliminated a problem with the base unit by a) registering a different DECT phone to it. - The base still works fine. b) Leaving the handset switched off for an hour or so (press and hold the "OK" botton to switch off / on); then whislt it was working, registering the handset to a different base (Base 2). And guess what, after 30 mins the "BASE 2" message started flashing on the faulty handset.
So, if you already have an A110 extension handset, make sure it's also registered to base 1 and maybe try to get just the handset repaired via VTECH. (or just buy a new handset if they are available).
SOURCE: working one set of Vtech 6041 cordless phone set with another?
I have the vtech dect6.0 with one answering system and two remote docking systems.I can phone out from the remotes but cannot receive incoming calls from the remote.When I pick up the remote to receive the phone immediately shuts off.
SOURCE: Phones going dead
buy a new battery from ebay.
just type in the search box, 80-5808-00-00
(the battery number)
You should be able to get a replacement for around $6 incl shipping.
This worked for me anyway. (Same symptoms you described)
SOURCE: How do you keep Base Unit of Vtech phone clean
Hello! Go to;
www.puremobile.com/vtech-cordless-phones.asp
This company offers a large selection of screen protectors ; Although none that are specific for your phone. Find a product that is close in size and trim to fit.
Guru.................saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
