Canon PIXMA MP150 All-In-One InkJet Printer Logo
Posted on Dec 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I hav installed the new catridges for canon mp140 and it says ink absober is full,i can't print documents,what must i do to resolve this problem. Please help. Ronny - South Africa
Corne Viljoen
Level 2:
  • Expert 385 Answers
  • Posted on Dec 08, 2010
Corne Viljoen
Expert
Level 2:
Answers
385
Questions
0
Helped
107709
Points
969
Hey Ronny!Iunfortunately u cant replace that machines waste ink absorber!Even the manual says replace the printer as it has failed!Sorry!!
tip
True guide to reset ink tank absober full on canon mp140
Use this method with your own risk!!
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
Reset E27 Waste ink absorber full or platen waste ink absorber full for Mp140
turn off printer.
- put your finger and hold on/off with reset/stop button together
- turn on printer power switch
- release on/off button but in the same time still hold stop/reset button and then press on/off button again and hold.
- wait at the moment
- relese stop/reset button 2X.( your will see alarm led blinking for 2X)
- relese on/off button.
wait until your printer digital screen shows number 0.
- after printer panel screen shows number 0.
- press reset button 4x
- press on/off button 1x
wait until your hear printer roller is moving
after your hear roller moving, wait until your dont hear anything from your printer :)
then turn off and turn on your printer again and your will see your printer back to normal.
Ok world...Good luck
hopefully this can helped to solve your problems.
Thanks.
please leave your evaluation.
Extra download ====> Fix_IP1000InkOverFlow
My canon ip7240 is saying ink absober full how can i reset it ?
Resetting the waste ink absorber on a Canon printer can resolve some error codes that appear when turning it on.
  1. Make sure the printer is turned off.
  2. Press and hold the Resume button (triangle inside a circle).
  3. Whilst it is held down, hold down the Power button. ...
  4. Keep the Power button held down. ...
  5. Release the Power button.
More items...
Reset Canon Printer ink absorber ' Fix-KB
www.fixkb.com/2011/06/reset-canon-printer-ink-absorber.html canon ip7240 is saying ink absober full how can reset it Google Search
see if this helps you out.
Will not scan due to no colour ink. do not want to
hi,
As you dont want to use the colour ink,When you give the print command you wil get the print properties page ,In that you can select black and white so that you wil not use up the colour catridge. It uses black catridge only.
thanx
When i try to print, it says the ink catridge was run out.
When machine shows ink out, you must replace with new cartridge. If not the machine won work.
1helpful
3answers
Printing B&W on a Pixma MP800 with empty color cartridges
no you cant print with emapty colour catridges you have to install the other full catridges.
I dont want use colour catridge..how can i remove the catridge without disturbing the system?
Replace the ink
cartridge(s), or press the
OK button.
When selecting to press
the OK button, ink may
run out during printing.
Cannon MP145, I want to only scan not printing.
There is no solution for that, if you want only scanning, you need a separate scanner. This machine will only scan when all other errors are taken care of. And all inks are full.
Ink, copying and printing problems
canon MP 150 Series printer usB001
The waste ink absorber is full
old marine
old marine
ZJ Limited
ZJ Limited
