Question about Fujitsu Heating & Cooling
My Fujitsu air condition had stoped working, it has flashing lights of Timer in green (continuously) and Operation light in red (5 flashes).
Posted by nurit_yaheli on
R Subramaniyam Iyer
  • 2,133 Answers
The unit is under time setting. You have to cancel the timer by dis connecting the power and restart.
Posted on Dec 08, 2010
Fujitsu Aircon model AST24PBA-W has green Timer light continuously flashing and red Operation light giving 5 flashes. Outside unit fan will not run. What does this code indicate has failed?
Most likely a faulty fan motor. You will need a tech to diagnose correctly as this uses a DC motor which has a circuit board inside so has very specific tests. Other possible faults for this code are compressor rotation error, CT abnormal or current trip all of which will need a tech to diagnose.
Nov 04, 2017 | Fujitsu Heating & Cooling
Fujitsu asta18lcc has a constantly fast flashing green light and the red light flashes slower 5 times with a small gap between each 5 flashes. Unit wont work at all apart from lights.
The red light (operation) flashing 5 times can be one of four things depending on the green light (timer) but the green light should flash at the same rate as the red light, not faster - either 2,3,5 or 6 times. Anything other than these is abnormal and you will need a tech to diagnose.
Could be a faulty controller board or compressor.
Apr 22, 2017 | Fujitsu Heating & Cooling
FUJITSU Inverter wall mounted split air conditioner Model : AST12LSBCW not working, flashing lights
This is a "PFC circuit abnormal" in the outdoor unit meaning that the outdoor controller board is faulty. Try turning the machine off at the isolator switch for 10 mins, then back on to see if the error resets. If not you will need a new controller PCB.
Nov 15, 2016 | Fujitsu Heating & Cooling
What does error message mean on Fujitsu inverter aircon model ASTA30LCC. red operation light flashes on 5 times with green timer light flashing on twice. Can someone please tell me what the fault is?
This is an "Outdoor unit control error" - specifically, a "Current trip error". There is a problem with one or more of the outdoor boards and you will need a tech to diagnose.
Jul 18, 2016 | Fujitsu Heating & Cooling
Fujitsu ASU18RLQ heater/air conditioner with 2 green and 7 red flashing error lights
Here is a link to the error codes.
http://www.fullyairconditioned.com.au/images/uploaded/files/fujitsu%20fault%20code%2
0split%20system.pdf
Hope you find an answer there.
Feb 15, 2013 | Fujitsu ASU18RLQ Single Zone Wall Ductless...
Fujitsu ASTA12LCC operation and timer lights flashing
You need to record how many times each light flashes before it pauses and then repeats. This indicates a specific error that a tech will be able to diagnose and directs them to the components that have failed.
Dec 27, 2012 | Fujitsu 18C1 Air Conditioner
Ihave a fujitsu air conditioner model asta18lcc about 2 yrs old when I turn it on fan works but room wont get cold or hot,red operation light does not stay on but green timer light flashes on. thanks...
The lights on the front panel indicate fault codes dependent on the amount & intervals of the flashes. Fujitsu units carry a 5 year warranty so check with your local Fujitsu store for the agent in your area.
Aug 13, 2010 | Fujitsu 24C1 Air Conditioner
Outside unit not working
you most likely need a service guy to go out and take a look
Mar 15, 2009 | Fujitsu 18C1 Air Conditioner
I have Fujitsu air conditioner Model abt45rba3w Serial t000147 The unit will not operate. The red operation light is flashing fast continuously and the a/c unit will not turn on. The timer light is...
Have you checked for compressor operation? If it is not running you may need to replace the hard start relay/capacitor. If you remove it and get the numbers it is available on ebay for a fair price. eBayeBay
Sep 07, 2017 | Fujitsu Heating & Cooling
Heating & Cooling Logo
Top Fujitsu Heating & Cooling Experts
Marvin
Marvin
Dan Webster
Dan Webster
jdthefixer
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
