Question about Avanquest My Invoices And Estimates Deluxe (gb0u3c0gn0000me066) for PC
When i try to open estimates & invoices i get a pop up that say's that i have selected a file from a previous version. this file can be automatically converted to work with the current version. click ok to convert this file. when i click ok it ask for a customer file & a product file. every time i try to put a customer file or product file in it say's file does not exist or cannot be opened
Posted by southelectri on
NinaE
    President:
  • 3,278 Answers
Hello.
Sounds like the file you are trying to open is corrupted. If you have a backup file, backup the current file for safekeeping and use a recent backup file.
When the program prompts, then creates a backup file for a database, it has a .bak suffix. However it also creates a folder in the 'Safe' folder under c:\program files\estimates. Locate the most recent version of the db files in the Safe, copy the folder to the c:\documents and settings\...\Invoices directory, and the most recent uncorrupted database should be available.
Hope this helps.
Posted on Dec 08, 2010
Data saving error
Per Avanquest: We have found out that this randomly happens due to an interruption in saving the data in MyInvoices and Estimates Deluxe version 10. We recommend that you do the following steps:Go to the Task Manager.On the Applications tab, click on MyInvoices and Estimates.Click on End Task.Relaunch MyInvoices and Estimates.Create a new invoice/estimate and save it.
If that fails to resolve the issue, you should also try the following:
Close MyInvoices and Estimates.Restart your computer.Relaunch MyInvoices and Estimates.Create a new invoice/estimate and save it.
Note: The task you need to end is MIED.exe
May 23, 2014 | Avanquest My Invoices And Estimates Deluxe...
I have an error message on My Invoices & Estimates when trying to save an invoice data saving error: Save Entity exception. It wont let me save it or back out of it... What do i need to do to correct...
  1. Go to the Task Manager.
  2. On the Applications tab, click on MyInvoices and Estimates.
  3. Click on End Task.
  4. Relaunch MyInvoices and Estimates.
  5. Create a new invoice/estimate and save it.
  1. Close MyInvoices and Estimates.
  2. Restart your computer.
  3. Relaunch MyInvoices and Estimates.
This worked for me without losing any data other than the invoice I was creating. Always make backups so if your data file is corrupted, you can easily restore it. Hope this helps.
http://support.avanquest.com/support/solutions/articles/1000173898-when-saving-an-invoice-or-estimate-i-get-a-data-saving-error-message-how-can-i-correct-this-
Dec 06, 2012 | Avanquest My Invoices And Estimates Deluxe...
Home and business shutdown
If you have a bootable CD or DVD drive in your computer, download a copy of Hiren's BootCD, or Parted Magic, and boot to that operating system. Then you could copy the files off to another drive such as a flash drive or external hard drive.
May 08, 2017 | Intuit Quicken 2008 Home & Business Full...
I am working on doing a fresh reinstall on a computer for someone, but they need me to save thier "My Invoices & Estimates Deluxe" information & reload it on the computer once I restore...
You have to backup all the require data to an external storage media first. If your are not familar with the software data backup. Ask your principal help or the person who operate on the system, to backup their vital data for to the external storage media, because you don't know which files are important.
Once you have install the OS, On installing "My Invoices & Estimates Deluxe" make sure the name the company file the exact same as the back up file name. If not you will not be able to load the backup files ie. you get errors opening the backup files.
Hope it helps.
Nov 22, 2010 | Avanquest My Invoices And Estimates Deluxe...
We just upgraded to Windows 7 and we cant get our old invoice program to load. Its Proventure Invoices & Estimates version 1.0.0B . Can you help us?
Your accounting software may not be compatible with Windows 7. Check the manufacturer's website to see if it is or not.
You can also try the Windows 7 compatibility fix.
To do this, follow Microsoft's suggestions here.
Sep 16, 2010 | Avanquest ProVenture Invoices...
Printing problem with my invoice and estimate
MyInvoices & Estimates Deluxe
Open Company file error.
Exception: Unable to load DLL 'sqlceme35.dll': The specified module could not be found. (Exception from HRESULT: 0x8007007E)
Jul 27, 2008 | Avanquest My Invoices And Estimates Deluxe...
"My Invoices & Estmates Deluxe" - Repair corrupt '.inv' invoice file
When the program prompts, then creates a backup file for a database, it has a .bak suffix (not amazing). However it also creates a folder in the 'Safe' folder under c:\program files\estimates... All I had to do was locate the most recent version of the db files in the Safe, copy the folder to the c:\documents and settings\...\Invoices directory, and the most recent uncorrupted database was readily available for File Open. Voila.
May 30, 2008 | Avanquest My Invoices And Estimates Deluxe...
Unable to Email Invoices
if you are using office it can be set to not send some attachments.
it is usually safe to rename the extensions on them to something stupid.
make a copy of the file first .
but to rename the extension you have to see it first.
open any folder and goto the tools/folder options/ uncheck the hide extensions for known file types.
hit ok
then you can see the extension of all file names.
See if that works for you.
Other times its the size of the file you are sending
the normal limit is 2 meg for email.
Jan 30, 2008 | Nova Development Invoices & Estimates Pro...
Avanquest My Invoices And Estimates Deluxe (gb0u3c0gn0000me066) for PC Logo
262 people viewed this question
Top Avanquest Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Sheldon Dedek
Bill Boyd
Are you an Avanquest Computer and Internet Expert? Answer questions, earn points and help others
