True Freezer TA1F-2HS Freezer, Reach-in, One-Section, 31 cu. ft., 34-3/4"dp, digital thermometer, 4" swivel ... Logo
Posted on Dec 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Evap fan not comin on - True Freezer TA1F-2HS Freezer, Reach-in, One-Section, 31 cu. ft., 34-3/4"dp, digital thermometer, 4" swivel ...
Robert Moller
Level 3:
Guru:
  • Master 1,524 Answers
  • Posted on Dec 13, 2010
Robert Moller
Master
Level 3:
Guru:
Answers
1524
Questions
Helped
579622
Points
4327
The coil temperature must reach 25*F. before the fan delay allows the fan to turn on.
2answers
Delay on evap. fan sistm.404a
Give the evaporator a chance to get cold, then check you've got power to the fan, via the evaporator thermistor and door switch
True gdm12 evap fan runs all the time evev with the compressor off wiring seems not to have been touched
evap fans will run continuiously on this unit,it is normal. fans stay on to circuilate air evenly inside unit.
No evaperater fan run,compressor running,coil is frosting but no voltage to inside fan.
Look to the fan delay/defrost terminator that is located inside to the evap. It is usually attached to the evap coil. check there first.
3helpful
Fans not running, everthing else runs. True model T-72F reach in
In most cases, there is a device located in or on the evap that senses the temp of the evap. This can be a defrost terminator/fan delay. Sometimes they are separate devices and sometimes they are a 2 in 1 device. If the evap does not get cold enough, the fans will not come on. Usually about +20 degree F. It is to prevent circulating warm air after a defrost and to keep from overloading the compressor after a defrost as heat is generated by electric elements. I would look to see if the defrost terminator / fan delay has malfunctioned, then I would check the refrigeration system performance.
Compressor works, fans not working, ice maker not filling with water. what is wrong
several things could cause this 1 not coolind evap caused by freon leak evap needs to get cold before fans run most modles 2 bad fans 3 im wont fill untill it reaches about 10 degrees you may need service tech sorry
Jan 29, 2010 • Freezers
3answers
Fan in freezer not working
It runs when the compressor runs except when it's in the defrost cycle. If you have an electronic control instead of a defrost timer the control could be the problem since it runs the fans. You can test the evaporator fan. See how here> How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
1helpful
My walk-in's ceiling panel is dripping
The coil in the conditioned space is called the evaporator.
If the water droplets are forming on the ceiling around the evap, it is due, most likely, to the defrost cycle being too long.
Defrost cycle: compressor stops, evap fans stop, electric heaters in the evap come on to clear any ice/ frost on evap fins/ coil.
The ice/ frost melts and some of it turns into vapor. As it hits the cold ceiling surface, it condensates into water droplets. Defrost cycle could be too long. Usually 4 time aday and no longer than 30 minutes should be enough unless there is high humidity.
There could be another cause.
Normally, after a defrost cycle terminates, the evap fans do not come on, due to a delay control. This prevents circulating warm are due to the heaters. The compressor comes on and cools the evap down to, usually 20 degrees or so, and then the fans come on. What could be happening is, the fans are coming on too early and blowing the water driplet off the evap and onto the back wall of the unit.
A third item, is to be sure that the condensate drain is "P" trapped. The prevents warm, outside air from being drawn in and causing exess frost build up, thus excess water and vapor.
Good luck and hope this helps
2helpful
We have a true T49F freezer and the evaporator fans are not running. The compressor is running on startup. The coils are cold. But are freezing up. Shouldn't the fan be on, or does the cabinet have to...
Freezers have a sensor that is referred to as a "Fan Delay/Defrost Terminator". It senses the temp during the defrost cycle. Usually, when the evap temp reaches about 50 degrees, there should not be any frost or ice on it. This device terminates the defrost cycle. It also keeps the fans off so warm air is not circulated. When the evap gets to about 20 degress or so, the sensor switches on the evap fans. If the fans are not coming on, either the sensor is bad or the evap is not reaching the proper temp to cause the sensor to turn on the fans.
Hope is helps to clear up some things and point you in a direction as to what might be going on.
Evap fans not turning on
If this is a commercial unit, you're too low on refrigerant (freon). Freezer should be about a minus 10 degrees for the evap and high side is ambient converted to a psi for the type of refrigerant that is in the system plus 25-30 psi.
The evap fans will not come on because the evap is not cold enough.
Hope this helps and good luck.
Apr 09, 2009 • Freezers
Unit not freezing , evaporator fan wont run
If this is a Bev-Air, don't think the door switch will control the fan. At the evap, there is a temp sensor called a fan delay. When unit goes into defrost mode, this warms up. Some also serve a dual purpose. It will terminate the defrost cycle at a certain temp., say 51 degrees or so, at the evap. Anyway, when unit comes out of defrost, it keeps the fan off so it allows the evap to cool quicker and to prevent circulating warm air. This could be your problem. Not a hard fix but they can be a pain sometimes. Outside chance that the unit is low on refrigerant (freon). This will not let the evap get cold enough to trip the sensor back into position to turn the fan on. Good Luck. Restaurant Parts and More carry alot of Bev-Air stuff. 1-888-814-1110. Ask for Rick
Top True Freezers Experts
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Are you a True Freezer Expert? Answer questions, earn points and help others
