Question about Gemmy Holiday Lightshow and Timer with Sound, 5552194
What is the fuse manufacturer 6G8A and where to purchase the fuse.
Posted by ebdex11256 on
Phil Mendez
    New Friend:
Today I purchased a 10 amp 125v ceramic from True Value and so far no problems. How long do you run your lights each night?
Posted on Dec 10, 2011
Davebrat77
    New Friend:
I used a 10 amp 250v ceramic fuse works fine
Posted on Dec 02, 2011
Why am I continually blowing 3 amp fuses upon energizing the unit?
put a multimeter on the out let side of the fuse holder to earth and check for a short circuit
If you get a resistance reading then maybe the fuse size is incorrect
contact the manufacturer service division on line and get the correct fuse size for the application
Apr 23, 2015 | Water Heaters
No power
i had the same problem and did what this fella suggested and worked just fine. There is usually a 125V, 20 AMP line fuse inside the microwave, mounted at the point where the power cord enters the back of the unit. Unfortunately, you will need to uninstall the oven (if this is an over the range model), UNPLUG it and remove the exterior case to access. The case comes off in various ways depending on manufacture and model. If the model number you listed this question under is correct, the line fuse is connected in line with the power cord inside the unit and is listed as part of item 4 in the parts listing (part number STD384200).
If the line fuse is blown, you can usually purchase a box of fuses at a hardware store for just a little more than what the manufacturer charges for a single fuse. 125V, 20AMP Ceramic Slow Blow fuses are recommended.
Feb 06, 2012 | Emerson MW8102SS 1100 Watts Microwave Oven
2000 Mercury Sable Fuse diagram
Hello, to get the complete wiring schematic for 2000 Mercury Sable need to contact the dealership or auto electric companies that specialize in auto electrical systems.
Now, if don't know which fuse is which then look in your own manual or on inside of the lid for the fuse box. American auto manufactured do use relays for some circuits and where they are located on any automobile is the preference of auto makes.
You auto manual should have a diagram of the fuses and what each fuse represents. If not then purchase an auto repair manual of your specific auto. GB...stewbison
Oct 19, 2011 | 2000 Mercury Sable
Where can i purchase a fuse for my dolphin power supply? Thanks
You can find this fuse in just about all online pool parts supply stores... When searching for the best deal..Use this info below... I would try radio shack first and see if they have the correct size/amp rating.. If not, order on-line.. One site of many is ... poolpartsonline.com???
Good luck and hope this helps...
Product Specifications Part #: 3295-023 Manufacturer: Maytronics Manufacture Code: 1930251 Product Dimensions: 0.75" X 0.25" Product Description INYO # 3295-023 MAYTRONICS # 1930251 GENERAL DESCRIPTION: THIS IS THE 2.5 AMP FUSE USED IN SOME DOLPHIN POWER SUPPLIES THIS IS A SMALL CLEAR GLASS FUSE LENGTH:3/4" DIAMETER:
Aug 26, 2011 | Dolphin Maytronics Advantage
My coffee makers digital screen is not seen. Cannot set time or turn on coffee maker. Checked outlets all fine. Just purchased. Only used a few times.
The coffee maker has clearly a manufacturing flaw, from your description the thermal fuse has opened and is welded to the heating element. The only option is return the unit to the place of purchase.
May 28, 2011 | Mr. Coffee JWX27 12-Cup Coffee Maker
I purchased a Star waffle maker in April and now it will not heat up who do I talk to about this problem?
Nearly all appliances that use high heat in their operation such as your waffle maker, coffee makers, toasters, use a thermal fuse to prevent fire. Unfortunately, these fuses are all coming from China and are very poorly made. Additionally, they are mostly welded to their mounts since the heat to which they are exposed is too high for soldering or fuse holders and are not user replaceable.
You will need to ship back your waffle maker to the mfr. for repair and you should have plenty of time left on your warranty.
Contact the manufacturer for return instructions:
Star Manufacturing International
Aug 20, 2010 | Star Kitchen Appliances - Others
In December 2009 I purchased an Emerson Microwave model MW8119SBM. The other day it just stopped working. All the lights on it went out. I tried plugging it into other outlets that were known to be good...
This appliance has one year warranty from the date of purchase.
Call the manufacturer to find the nearest service center near you.
Emeron's TOLL FREE: 1-800-695-0098.
Jun 10, 2010 | Microwave Ovens
Where is the fuse located?
If the model number is correct, there is a small input line filter board with a 125V, 20 AMP line fuse inside the microwave. Its usually mounted on a small input line filter board at the point where the power cord enters the back of the unit. You will need to UNPLUG the microwave oven and remove the exterior case to access. The case comes off in various ways depending on manufacture and model. I found this illustration at pcappliancerepair.com based on the model number you listed this question under:
http://pcappliancerepair.com/model-display.php
The line filter is listed as item 1420. The fuse will be mounted to this board.
You can purchase replacement fuses at any hardware store. You can usually purchase a box of fuses at a hardware store for just a little more than what the manufacturer charges for a single fuse. 125V, 20AMP Slow Blow fuses are recommended.
If you have any questions, or need assistance troubleshooting, please post back and let me know. I hope you find this information helpful.
NOTE: Make sure you take any resistance readings with the microwave UNPLUGGED and the component under test isolated (removed) from the circuit.
Apr 24, 2010 | GE JES1290 Convection/Microwave Oven
My DV6000 was hit by a power surge during a lightning storm. It is completely dead. no lights or any indications of power. I have multiple batteries and AC adapters so I know it is the laptop. Is there...
No, there is no fuse.
Is the manufacturer's warranty still valid?
Did you purchase the computer via a credit-card that "doubles" the warranty?
Did you purchase an "extended" warranty from the manufacturer, when you "registered" it?
Did you purchase an "extended" warranty from the retail store?
Otherwise, find the nearest authorized HP repair outlet, and get it fixed.
Nov 18, 2009 | HP Pavilion dv6000z Notebook
Toshiba 42H81 Fuse Type
Speed rating is micro = any chemical micro fuse will work,5 amp, of course.Not necessary to use Mfr. part........T.
May 27, 2008 | Toshiba 42H81 42" Rear Projection...
Gemmy Holiday Lightshow and Timer with Sound, 5552194 Logo
1,692 people viewed this question
Top Gemmy Toys Experts
NOEL
NOEL
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a Gemmy Toy Expert? Answer questions, earn points and help others
