Computers & Internet Logo
Anonymous Posted on Dec 08, 2010
My modem ADSL data light keeps flashing and sometimes does not appear affecting my ability to acces the Internet. I usually have to re-boot my computer and this seems to solve the problem for a time. It is very inconsistant and anoying. Thank you M. Davis
Anonymous
Level 3:
Guru:
  • Master 825 Answers
  • Posted on Dec 08, 2010
Anonymous
Master
Level 3:
Guru:
Answers
825
Questions
0
Helped
239086
Points
2508
I usually have to re-boot my computer and this seems to solve the problem for a time. It is very inconsistant and anoying.Thank youM. Davis
ADSL DATA light flashes says there is internet activity (Internet status: Connected)...
ADSL DATA when off says there is no internet activity (Internet status: Not Connected)...
This occurs when there is a lot of noise in your telephone line...
It is adviced to do a line test in this case to find the amount of noise in your line...
If there is a lot of noise your modem will lose the internet connectivity and will try to re-establish the connection with ISP...
In this case the ADSL DATA light switches between OFF and ON...
One more thing...
ADSL SYNC light should be steady...
If it is blinking is says there is no syncronisation between your modem and ISP...
Testimonial: "Problem solved Thank you for your help."
1helpful
What happen when a adsl line work with a phone but not with a router
The phone line does two jobs. Voice phone which is what it was originally used for and ADSL modem which works at a high audio frequency.
Somewhere between the phone socket and the modem should be a filter splitter. One part goes to the phone and the other to the router. Make sure you have that.
The modem will have a power light and several additional lights. Assuming the power light is on we are interested in two of them; The ADSL light and the Internet light. When you switch the modem on you should first see the power light flash then go solid. Then the ADSL light will flash and then this should go solid. If this light does not come on then you have not plugged the phone wire in properly. If this light just keeps flashing slowly then the modem can't see an ADSL signal on the phone line. If you have a spare router you could try it and see if the ADSL light goes solid on that.
If the ADSL light is fine then the modem has locked onto the signal on the phone line, sync'ed. If not then this is the problem you must solve. Ask your ISP if service is set on your line.
The next light is the Internet light, this maybe a symbol like an i or a world. This light will begin flashing then go solid. It will flash with Internet traffic. This means you have Internet, as far as the modem is concerned. If this light does not stay on then your ADSL account name and password maybe wrong. You can correct this but that's a different question you need to ask.
Wt8951nd
Power cord
RJ-11 telephone cable coming from a splitter or the extn. line of your landline phone.
Ethernet cable coming from your Desktop/Laptop connecting RJ-45 port
Most standard ADSL modems have four/five lights in the front :
Power light to indicate electric power to the modem.
ADSL light indicates the status of ADSL sync. When the modem is synchronized with the ADSL line card at the other end of the circuit/loop, the DSL light will be steady green.
LAN light will glow steady green when the modem detects a successful link to a computer or router ethernet port.
ACT i.c. Activity light glows when the modem is sending and/or receiving data on the lan and wan. It will vary between very slow to fast flashing and steady green to indicate lan/wan traffic.
for more help visit CBR Tech Solutions
Blinking Internet light on frontpanel.
Try to pull the wires and restart your modem if there are no changes you should ask fof techy assistance
Definition of ipadsl
Hi. the definition of IPADSL is :
Internet
Protocol
Asynchronous
Digital
Subscriber
Line
I think what you are referring to is a fixed IP address, using adsl services
Your internet provider can either assign you a static/fixed ip address, or gave it be dynamic, or random.
If it is dynamic, it gets set new everytime your computer begins it's interface with your router.
An adsl modem is the type of modem that allows for high data rate transfers over standard copper lines that are associated with the telephone system.
Usually these lines do not carry high bandwidths of data, but an asdl modem aloows for multiple layers of data at once.
Belkin ADSL modem F5D5630au4 keeps losing conection
are you running filesharing? sometimes too many connections at once will cause the modem/router to crash and reboot
Belkin router is unable to connect to 2Wire ADSL modem/router. 2Wire router has DHCP server enabled and Belkin has DHCP server disabled. Belkin is set to obtain an IP automagically. 2Wire IP is...
If the Internet light is off then there is a problem with the phone line to the ADSL modem or the modem is faulty or there is a problem at the telephome exchange.
Disconnect the phone cable at the ADSL modem and connect a phone handset to this cable - check for a dial tone and that you can dial out.
If you don't get a dial tone, use a different or new phone cable.
If the phone line is OK then : -
Ring your ISP to get them to test your connection to your ADSL
modem.
RouFlashing ADSL light
have yo properly configure the setting imean dsl account ,dns setting etc of belkin
1helpful
Ethernet light flashing
Check your DSL Filters on your house phones or anything connected to the phone line EXCEPT the modem. The modem should not have a filter on it. If this doesnt help I would recommend getting your ISP out to test the line because sometimes the resisitors or hardware in the box goes bad or at the DSLAM.
On and off line every 20 flashes.
Have you attempted to connect the internet after the router stops flashing? Do the lights start flashing again? If you do, then it would be considered normal.
If they don't and you do not have an internet connection, try the next step.
Next, plug your computer straight into the modem - Do you have an internet connection now? If you do, your router may require configuration.
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
