Hi Friend,
In this case as you have told me that you have other laptop which is working fine wirelesly. I would like you to check the IP address of the system in which you are facing the issues.
To check the IP address:
1) If system has XP
Click on "Start" and then "Run". Type "cmd" in Run and hit enter
A black screen will pop up, in that type "ipconfig", where the cursor will be blinking
Check the IP adress under " Ethernet adapter local area connection" & " Wireless adapter"
2) If it is Vista/Win 7
Click on Start again and in Search field type cmd and hit enter
Same black screen will pop up and repeat the same above steps in the black window and check the IP adress
Testimonial: "thanks for help problem sorted"
