Health & Beauty Logo
Posted on Dec 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Panasonic ES8243 Wet/dry razzor. It has an LED window with an icon that just poped up. It looks like the head of the razor with two arrows circling around it. Not sure what it means. Can you please advise? Thanks. Jeff
shaveroutlet.com
Level 3:
  • Health & Beauty Master 1,652 Answers
  • Posted on Dec 07, 2010
shaveroutlet.com
Level 3:
Answers
1652
Questions
0
Helped
765510
Points
4209
It means it's time to change the head. You will find replacements at shaveroutlet.com. See link below
http://shaveroutlet.com/catalogsearch/result/?q=es8243+foil
SERIAL # ON PANASONIC WET/DRY RAZOR
If you are trying to located a serial number, it may be on the box that the razor came in.
1helpful
Is there a replacement battery for a Panasonic ES365 Wet/dry Razor?
yup...18 bucks....
https://www.ebay.com/itm/New-Shaver-Battery-for-Panasonic-ES364-ES365-Razor-/181605638343
1969 Remington ladies electric razor model Cl how to use it
Women's Shaver Parts' Parts and Accessories ' Remington ...
www.remingtonproducts.com/.../womens/shaverpart...
Remington ProductsRemington women's hair removal replacement parts. Electric shaver parts, wet dry shaver blades, shaver heads and cutters, shaver cords, ... I have a Remington Smooth & Solky Plus Wet/Dry Rechargable Shaver (Model: WDF-5000) and am ...
Women's Electric Shavers - Remington Products
www.remingtonproducts.com/womens/.../wetdrysha...
Remington ProductsRemington Women's Hair Removal Wet Dry Shavers ... Wet/Dry Shavers. Smooth and Silky 4 Blade System Rechargeable Shaver With Almond Oil; $39.99.
I have a Panasonic ES8243 and i jave had it on the charger for days now it wont charge i also have a light on looks like the head with a arrow on it. I just cleaned it really good and I just replaced the...
Could be one of several things:
1) A bad charging cord (have it checked, or try another if you have one).
2) The rechargeable battery is simply dead.
3) The charging circuit is non-functioning.
It's rare that these devices are worth fixing...
Sep 10, 2014 • Cell Phones
LOST DIRECTIIONS FOR RECHARGING PANASONIC WET/DRY WOMEN'S ELECTRIC RAZOR ES2207. Thanks!
You will find the instruction manual at shaveroutlet.com. See link below. When page opens, click the 'user manual' link near the 'add to cart' button
http://shaveroutlet.com/women-s/panasonic-es2207-close-curves-rechargeable-wet-and-dry-ladies-shaver.html
Playback flickering
The most common cause of this is dust, debris or contamination on the heads.
Firstly, it's extremely important that you use only DRY LUBRICANT type DV tapes on the Canon branded camcorders.
Different manufacturers design their heads to be used with either Dry or Wet (coating lubricant type) tapes - NEVER BOTH. Canon is DRY type.
Consumers are led to believe that they should be using well known branded DV tapes, such as Sony. This is fine, if your camcorder is a Sony. However, you should NEVER use Sony tapes in your Canon - Sony tapes are of the WET type.
So, the question is, "Are you currently using Dry or Wet type tapes, or a mixture of both?" If you have used either a WET tape, or a mixture of both in your Canon, then this may have contaminated your heads.
If this is so, then don't panic - simply run a special Head Cleaning cassette (for Dry tapes) in your Canon for no more than 5 secs. Note: your heads are very delicate, so only run the cleaning tapes for a few secs at a time.
Also, try to avoid recording over the cassette too many times, as the quality will sometimes degrade each time.
An example of the Dry tapes are the Panasonic ones (Myself and other Pro Videographers often use Panasonic Prof, Studio or Master Quality tapes, as these are some of the better quality Dry tapes on the market).
As your XL2 is a Pro Camcorder, I recommend you stick with Studio quality (or higher) cassettes.
See this link for Dry DV tapes: http://cgi.ebay.com/Panasonic-mini-DV-digital-video-cassette-AY-DVM63SQ-5pk-/170645949017?pt=US_Camcorder_Tapes_Discs&hash=item27bb4a8a59
or
http://cgi.ebay.com/5-Panasonic-Master-HDV-HD-video-tape-HC9-Mini-DV-/220519311691?pt=US_Camcorder_Tapes_Discs&hash=item3357f9a94b
See this link for Head Cleaner cassette: http://cgi.ebay.com/MiniDV-mini-DV-Panasonic-Head-Cleaner-Cleaning-Tape-/220683036059?pt=US_Camcorder_Tapes_Discs&hash=item3361bbe59b
If the problem still exists after head cleaning, then suspect either a faulty cassette (most likely) or damaged heads requiring service.
Let me know how you get on...
Scott
"If this has helped you, please be kind enough to leave a testimonial"
Top Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Health and Beauty Expert? Answer questions, earn points and help others
