Nokia E71 Smartphone Logo
Posted on Dec 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When i plugged the usb cable of my nokia e71 to a pc. the mobile ask for the connection mode. the computer doesn't detects the mass storage device though i select mass storage mode. neither the pc suite detects my mobile. and i am sure that my data cable is ok coz it worked for another mobile.
Muntejaya Ginting
Level 3:
  • Master 10,422 Answers
  • Posted on Feb 06, 2011
Muntejaya Ginting
Master
Level 3:
Answers
10422
Questions
Helped
2469725
Points
19564
1helpful
How can I download music to my fusion2 phone
First you:
2.9.1 Using the microSD Card as USB Mass Storage
To transfer all your favorite music and pictures from your PC to your mobile phone's microSD card, set the microSD card as USB mass storage.
1. Connect your mobile phone to your PC with the USB cable provided. Your PC will detect the microSD card as a removable storage device.
2. Open the notification bar, and then touch USB connected.
3. Touch Turn on USB storage in the dialog box that opens to confirm that you want to transfer files You can now transfer files from your PC to your mobile phone's microSD card. When your microSD card acts as USB mass storage, your mobile phone will not use this memory space. Ensure that you follow the correct procedures to disconnect the USB mass storage device (your mobile phone) from the PC when you have finished transferring files.
Then:
8.3.1 Copying Music to the microSD Card
1. Connect the phone to your computer with a USB cable and mount the microSD card.
2. On the PC, navigate to the USB drive and open it.
3. Create a folder in the root directory of the microSD card (for example, Music).
4. Copy the music from your computer to the folder you have created.
5. After copying music, unmount or eject the drive as required by your PC's operating system to safely remove the mobile phone.
6. Disconnect the mobile phone from the PC.
Once done open music player and play music.
Ref: http://www.att.com/support_static_files/manuals/ATT_Fusion2.pdf
Computer doesn't recognize garmin
Your computer uses USB Mass Storage Mode to detect your Garmin unit. If your computer does not detect your Garmin unit, you can try these troubleshooting steps:
Unplug the USB cable from the computer.
Turn the unit off and then back on again.
Plug the USB cable into your computer.
The unit either automatically goes into USB Mass Storage Mode or displays USB Mass Storage Mode as an option on the screen.
Note: If your computer still does not detect the unit, make sure that you plug the USB cable directly into the computer USB port and not the USB hub. If the cable is already plugged directly into the computer, try plugging it into a different port.
If you still experience problems, please contact Product Support.
Garmin car gps
E71 not being detected in nokia pc suite
Go into settings and change the default connection mode to "ask" or "prompt" then when you connect you should be able to select other options.
How do you get music to save on a new 4gb memory card on a nokia E5 instead of saving in phone memory
Transfer music from a computer
You can use the following methods to transfer music:
• To install Nokia Ovi Player to manage and organize your music files, download
the PC software from www.ovi.com, and follow the instructions.
• To view your device on a computer as a mass memory device where you can
transfer any data files, make the connection with a compatible USB data cable
or Bluetooth connectivity. If you are using a USB data cable, select Mass
storage as the USB connection mode. A compatible memory card must be
inserted in the device.
• To synchronize music with Windows Media Player, connect a compatible USB
data cable, and select PC Suite as the USB connection mode. A compatible
memory card must be inserted in the device.
To change the default USB connection mode, select Menu > Ctrl. panel >
Connectivity > USB and USB connection mode.
I hope this information will be helpful. Thank you for using FixYa!
3helpful
I want to download music using my usb
Hi,you can transfer music to nokia 5800 from your computer(pc or mac). There are different ways of transferring music.if you have a PC, you can use PC Suite to transfer music files.the nice software that comes with the phone. If you have a Mac, you can use Nokia Multimedia Transfer (free download) and sync it with your iTunes.
how to put songs on nokia 5800-nokia pc suite
To transfer music as data files, make the connection with a compatible USB data cable. You also need to have a compatible memory card inserted in the device. View your nokia 5800 on a computer as a mass memory device. follows these steps: firstly, connect nokia 5800 with computer via USB data cable. then select Mass storage as the connection mode. A compatible memory card must be inserted in the device. then view the device from the computer file manager as a mass memory device. now you can fansfer the music files. after transferring songs, you can close the connection by remove the USB device safely from your computer.
Hope it helped.
I hv nokia e71 mobile.my e71 is not connecting with pc in any mode(pc suit ,mass storage ....)yesterday it was working properly but today its not connecting. When i was connect it to pc it gave a beep...
I had a very similar problem with my N73. One fine day it did not connect, the next time I tried it started working again. Another time it did not work and so on. But as time went by the times it did not work grew over the times that it actually did work. The problem was not with the software or PC but with the phone. I even tried changing the cable but there was no real difference. I think the USB connector part of the phone must have gotten damaged some how.
I however did find a different solution but slower, you can connect to your phone with PC suite/Ovi Suite using bluetooth. It works the same but is much slower thats all.
2helpful
I have albums in my pc and want to transfer the albums to my nokia 97?
Not sure if you meant photo album or music album??? Here is the steps for both, music first:
computer
music:
● To install Nokia Music to manage and organise
your music files, download the PC software from
www.music.nokia.com/download, and follow
the instructions.
● To view your device on a computer as a mass
memory device where you can transfer any data
data cable or Bluetooth connectivity. If you are
using a USB data cable, select Mass storage as
● To synchronise music with Windows Media
Player, connect a compatible USB data cable, and
select Media transfer as the connection mode.
Menu > Settings and Connectivity > USB > USB
connection mode.
This works for music, photos, or video:
Select Menu > Settings and Connectivity >
USB.
To have the device
ask the purpose of
the connection
each time a
compatible data
cable is connected,
select Ask on connection > Yes.
If the Ask on connection option is turned off or you
want to change the mode during an active
connection, select USB connection mode and from
the following:
● PC Suite — Use Nokia PC applications such as
Nokia Ovi Suite, and Nokia Software Updater.
● Mass storage — Transfer data between your
device and a compatible PC.
● Image transfer — Print images with a
compatible printer.
● Media transfer — Synchronise music with Nokia
Music or Windows Media Player.
Here is the link for your manual online:
http://nds1.nokia.com/phones/files/guides/Nokia_N97-1_UG_en.pdf
1helpful
My nokia 6500 slide is not detected on my p3 processor computer
hi ,
on your p3 laptop/desktop go to the device manager and update usb drives (DO NOT CONNECT your phone). Before that uninstall pc suite. Then reinstall again.And follow the on screen guide how to connect the phone.
2answers
Dear sir, My phone is not connect to the computer
first see if your phone is set to usb mode to check go to settings>usb mode and select the mass storage
3answers
Phone not detected by computer
For maasai1 disconnect your USB cable and upgrade to the latest Nokia PC Suite v6.86.9.0 when installed do 2 restarts on your PC, then open Nokia PC Suite and follow the connection instructions, bear in mind that it's not magic the CPU has a lot to do and it takes time to do it.
"Confucius he say: Man who lose key to girlfriend's apartment get no new key."
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
