Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
SOURCE: can i convert my dyna glo 75000 btu propane
I'm sure you can, contact the manufacturer and ask if they have a natural gas jet or orfice for your model heater, these are usually very easy to replace.
Posted on Feb 28, 2009
SOURCE: burning eyes and sore throat when heater is on
This heater should only be used in a very well ventilated area, the sore throat and burning eyes are from carbon monoxide.
Carbon monoxide is potentially fatal.
I cannot express how dangerous this is if used in a house or garage without the doors open
Please be careful and let me know if I can provide furthur assistance.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Posted on Mar 02, 2009
SOURCE: I have a 35000 btu propane reddy heater that wont ignite .
the thermocouple is bad.it needs to send a signal to the gas valve to say it's okay to stay running.replace it and the problem should go away.if not let me know
Posted on Mar 13, 2009
SOURCE: raw propane fumes and burning eyes
Ours didn,t burn liquid propane too well, so ccheck your connections on your tank for vapor or liquid.
Posted on Dec 18, 2009
SOURCE: 150,000 BTU propane Reddy Heater shuts off after ignition
Is there a frost line on your LP tank, if so you may need to replace the tank with a larger tank or refill your tank. This can happen if the tank your using is too low or too small (use 100 lb tank or greater). If there is no frost line it may be an issue with the thermocouple. The manufacturer offers a service manual and owner's manuals on there site. This should assist you... www.desatech.com Thank you
Posted on Jan 28, 2010
Nov 18, 2014 | All-Pro Heating & Cooling
Nov 16, 2013 | Mr. Heater Portable Propane Forced Air...
Apr 20, 2011 | Reddy Heater-30-55,000 BTU Variable
Jan 20, 2011 | Reddy Heater-30-55,000 BTU Variable
Dec 20, 2010 | Reddy Heater-30,000 BTU Propane Forced-Air...
Dec 04, 2010 | Reddy Heater-30-55,000 BTU Variable
Nov 19, 2010 | Reddy Heater-30-55,000 BTU Variable
Mar 13, 2009 | Reddy Heater-30-55,000 BTU Variable
Oct 12, 2007 | Reddy Heater-30,000 BTU Propane Forced-Air...
May 15, 2014 | Coleman Propane Forced Air Heater...
124 people viewed this question
