Question about Ademco 10) Ademco 6148 Keypad Fixed English Replace 6128 6150
Why FC show on ademco 6148 keypad, - Ademco 10) Ademco 6148 Keypad Fixed English Replace 6128 6150
Posted by davidwm5461 on
  • Len Meyers Mar 17, 2012
    Fail to communicate
    Fail to communicate
Sean
  • 80 Answers
FC is for faliure to communicate. Need to check systems connection to monitoring station. Did anyone work on your phone line(s) or did you change your phone company or service? GL.
Posted on Apr 23, 2011
Brad Evans
    New Friend:
FC is also used for the Fire Alarm part of the circuit. FC can show on new panels, because it it not programmed yet. For Vist 20p systems, Zone 1 is pre-programmed as a fire zone. To get around it, and use your keypad to get into the progamming mode, you would install a resistor on zone 1, program, and then you can move to that zone.
Posted on Dec 16, 2012
  • Brad Evans
    Brad Evans Dec 16, 2012
If keypad displays the FC code Can you still program a new master code?
I have never tried that because it has never been requested. "FC" is a higher priority. It means failure to communicate. So I would always correct that problem first and then change the master code. But I don't see why you would not be able to change the master code due to FC code. Gl.
Jan 31, 2015 | Honeywell Ademco Vista 20p And 6150 Keypad...
Remove FC code Ademco Vista 15P alarm sysem
FC means failure to communicate, call your monitoring company to test your systems communication. If your system uses or used your phone line call on a cell phone so you don't get cut off when you system tries to call to monitoring company. gl
Jun 05, 2014 | Honeywell Ademco Vista 20p And 6150 Keypad...
How do I change the battery for alarm keypad?
Most keypads are using a 4 wire conductor coming from the security panel. If you have a wireless keypad such as a 5828 should be 3 to 4 AA batteries and as simple as removing the screws from the access panel in the back.
Sep 12, 2013 | Honeywell 6148 - Ademco Fixed English...
How to remove the FC phone system part from a honeywell vista20p
To properly solve the problem, the system must be reprogrammed using the installers code.
Nov 09, 2012 | Honeywell Ademco 6160 Alpha Keypad Vista...
How to get rid of FC on keypad
Mar 25, 2012 | Ademco 1 Ademco 6150 6150pl3 6150pl2...
How to get rid of FC on keyboard
FC is failure to communicate, to clear the keypad you need to get a signal to the central station where your being monitored, it will clear when the receiver acknowledges the signal
Mar 25, 2012 | Ademco 10) Ademco 6148 Keypad Fixed...
There is a flashing error code on my keypad - FC. What does this mean? I had a service tech in to repair this problem and he said it was solved. No sooner did he leave and the "FC" began...
If you are not monitored, the FC will come up every time it tries to send a signal to a monitoring station. FC means 'Fail To Communicate" Contact me if you need further assitance
Jul 15, 2011 | Honeywell Ademco 6160 Alpha Keypad Vista...
How do I program zonig for my Ademco 6148 pad
The 6148 keypad is a fixed english keypad. It is possible to program your system from a fixed english keypad, but it is very difficult. an alpha keypad shows text descriptions of the programming fields. The model number is 6160. If you are doing your own programming, I would suggest replacing the 6148.
When programming, you're programming your alarm panel, not the keypad. The keypad is just an interface to the panel. If you have a tan box in your basement or a closet, that is your panel. There will be a sticker on the inside of the door of the panel that will tell you the model of the panel at the bottom. It will say Ademco Vista 10, 15, 15P, 20, or 20P.
From there you can go to the link below and find the installation and programming manual for your panel.
http://panelguides.com/panel-guides?task=viewcategory&catid=521
Hope this helps.
Mar 18, 2011 | Ademco 10) Ademco 6148 Keypad Fixed...
Ademco 10) Ademco 6148 Keypad Fixed English Replace 6128 6150 Logo
1,032 people viewed this question
Top Ademco Home Security Experts
Sean
oooga boooga
oooga boooga
Level 1 Expert
Vincent Migliore
Vincent Migliore
Level 1 Expert
Are you an Ademco Home Security Expert? Answer questions, earn points and help others
