SOURCE: iPaq 1910 backup battery replacement
try, http://www.pdasmart.com/products/19927ipaqparts1900.htm
SOURCE: how to change the backup battery of ipaq 1940?
This PDA is relatively difficult to take apart. I've done it myself and it was very difficult. It is not recommended by any means because you can seriously mess up your ipaq by taking it apart. On the site I gave you after you buy and receive the replacement backup battery, if you do it yourself, will give you a site to get instructions from. You can also send it in to have it done professionally.
SOURCE: The backup battery not working
Hello Paul,
Yes the battery can be replaced but this will require you to dissasemble the pda. The problem you face is a clear sign that this battery has failed. There has always been a problem with hp's battery measurement algorithm regarding that secondary backup battery. Altrough it is empty or even if you remove it, the program will still display a full bar. In order to change this battery you will need to remove the screws from the back of your unit. The casing will come off pretty easy. The back-up cell is a small coin like battery most probably wrapped in a green plastic shel. you should find a similar battery and connect the pins from the old one to the new. The battery size is not critical as long as you can make it to fit in the space inside. Try, however, not to use a very small battery because it will drain much faster then larger ones. Carefull when observing polarity.
If you need more informations please reply.
Bogdan.
SOURCE: Hp Ipaq h6340
@Fanara
in the fall the simcard reader or the sim card connectors where damaged.
I would take the pda to a professional for analysis.
SOURCE: Memory on HP ipaq 114.
there are two types of memory my friend
1. RAM
2. ROM both built in PDA
third type is Storage Card u can store music and photos there but u cannot merge it with RAM or ROM so pls try to understand this difference
secondly if u want me to help u out on this memory shortage
then u can reset the device i mean hard reset and re install ur applications by time ur ROM is occupied by some useless files and ur performance is de graded try to refresh ur OS
Hard reset
HP
iPAQ Setup Assistant
Use HP iPAQ Setup Assistant to simplify
configuring settings on your HP iPAQ.
lets you save the settings on your computer. This can help you restore
configuration settings on your HP iPAQ at any time. HP iPAQ Setup
Assistant also allows you to perform a factory reset on
your HP iPAQ and view detailed product information.
To hard reset HP iPAQ 114:
- press and hold the 3 buttons Windows, OK and REC
- press the reset button for about 3-4 seconds and release it
- release the 3 buttons
u can see the video for that but it is in russian lang but self explanatory
http://www.youtube.com/watch?v=BG68AzNBsds
third option is if u want to really get rid of this slow performance and shortage of space just get a clean CUSTOM ROM from
http://forum.xda-developers.com/ for ur PDA strictly at ur OWN RISK
pls rate me fixya if i have fixed ur problem
