SOURCE: Replaced HP LaserJet 2840 catridges and now [?][?][?][?] ! error
The OEM cartridges have a chip on them. If the aftermarket supplies do not have the right chip, missing a chip, etc., the machine will not recognize. Placing the old cartridge back in without any toner can give off the same message.
Try rebooting the printer without a cartridge in. Then install the cartridge, either one, and see if that helps. If not, wait for the OEM to arrive.
SOURCE: My HP printer CP1518ni gives me an error message
The clear one's are the empty cartridges. Try replacing those.
SOURCE: Printer will not recognize ink
The toner (not ink) cartridges in your printer have a security chip attached on the top at the right side. For the printer to work that chip must have a very good contact with the corresponding pins - first make sure that they are spotless.
You will also need to clean the the print head assembly. The print head contacts should be dusted free using a can of compressed air. It would be a good idea to clean the entire assembly if there is time as this could cause other printing problems. After using the compressed air, take a small lint free cloth with a small amount of isopropyl alcohol and wipe the contacts clean.
If this doesn't fix it then either you ar using an non approved set of cartridges or the printer is defective - you will gonna have to call a repairman.
SOURCE: I have an HP Photosmart
The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
If you prefer, you can skip this information and go directly to downloading the tool
SOURCE: When I replaced the black cartridge on my HP 6500
Try using the HP Print Diagnostic Utility in Windows - HP Customer Care (United States - English).
If you need more help come back.Post / thumbs / testimonial are welcome!
