Question about Simplex Kaba Ilco Unican 1000 keyless lock
How do I change the combination on my Unican 1000 keyless lock? thx john
Posted by jpandros on
sonic boom electronics
  • 1,557 Answers
The door must be open.
On models with the passage feature, make sure the passage feature is disengaged: turn knob or key should be in vertical position (A) (see figure 1).
1. Insert the DF-59 control key (B) into the combination change plug
assembly (
C) and unscrew the cylinder by turning the key
c
ounterclockwise. Remove the combination change plug to gain access to the combination change sleeve (see figure 1).
2. Turn the outside knob/lever once clockwise (all the way, until it stops) then release. The latch should not retract (see figure 4).
3. Enter the existing combination. On new installations, use the factory- set combination: depress 2 and 4 simultaneously, (release), then 3
(r
elease). You should feel a slight click as each button is depressed.
4. Insert the spanner wrench as shown in figure 2 to engage the combina- tion change sleeve (A). Gently turn the spanner wrench clockwise to the stop position (a slight click should be felt), then turn the spanner wrench counter-clockwise to the stop position (A) (see figure 3). Remove the spanner wrench.
5. Turn the outside knob/lever once clockwise all the way until it stops, then release. The latch should not retract (see figure 4).
6. Choose your new combination, write it down, then enter the new combination-depress buttons carefully (a slight click should be felt as each button is depressed).
Note: You can use one button or all five for a combination, but each button can only be used once. You can depress two or more buttons simultaneously as a step in the combination.
7. Turn the outside knob/lever clockwise once, all the way, until it stops, hold in position and make sure the latch is retracted (see figure 5).
R
elease the knob/lever.
Note: If your lock is opening on every turn of the knob or lever, except upon entering a code, this may be a ZERO CODE. Before attempting to remove the lock from the door, refer to the troubleshooting procedures outlined at bottom of this document for a zero code symptom/solution.
1000/L1000 Series FAQ
Changing the Code/Combination
hope this helps
and here is the link to the change code web site
http://www.locksonline.co.uk/files/pdf/Simplex_1000_CodeChange.pdf
good luck
please take the time to rank my advice
merry christmas
Posted on Dec 07, 2010
How to change lock combinasion
http://lmgtfy.com/?q=kaba+1000+change+combination
Mar 13, 2014 | Simplex Kaba Ilco Unican 1000 keyless...
Lost the df-59 key and need to change the combination
For $9 you can get the df-59 key and spanner wrench from this company:
http://www.ckilock.com/Mpage18.asp ,10th item down on page
C.K.I. Wholesale Lock Supply 1-800-445-5230
Their item number SMPBC201278
Hope this helps!
Feb 22, 2012 | Simplex Kaba Ilco Unican 1000 keyless...
Lost combination on the unican 1000! How do i get it back or set a new number in it?
I will give you several sources of information for you to pursue.
First is a link to a chart where you can download PDF files for your lock ( the L1000):
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13&obj=l1000
There is a link on that page where you can download and install Adobe Reader in order to open and view PDF files, if you don'ta already have it installed on your computer.
Aditionally, here is a link to a website wherein it is described how to change the combination on the unican lock:
http://www.lilocksmith.com/keyless_Locks/unican1000.htm
A Df-59 key can be purchased at this site:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx
The spanner wrench (SMPBC201278 Simplex:SpannerWrench $9.00) referred to can be purchased from this site:
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
May 17, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
I tried to change the code on a 1000 series lock and now I can't get any code to work
You have probably inadvertently created a lost combination situation. In the case of a lost combination, Kaba Ilco recommends that you call their technical service department:
"This is a lost combination situation.
Please call our Technical Service Dept.
For further information at (800) 849-8324
or (336) 725-1331."
They are located in North Carolina, so the best time to call is probably during east coast business hours.
Good luck--and please provide feedback if this helps!
Dec 03, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
I need a kaba ilco spanner wrench to change the combination on a 1000 series lock. where do i get it?
Sep 21, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
Want to reprogam keyless lock unican push button lock please advise ------thankk you...
Turn knob once. Put in present combination. Open screw on the top, Use a small rod or drillbit  that will fit into the hole. Press straight down on a lever that is inside of the hole,until it clicks. Turn knob completely(once) to clear old combination. Put new combination in, making sure that a click is heard upon pressing each button.  Try knob with both the old and the new combination. Each digit may be used only one time in the combination.
Dec 31, 2008 | Simplex Kaba Ilco Unican 1000 keyless...
Bought house from bank and trying to retrive lock combination
I'm trying to remove a unican lock from my door but I can't see how to get the handle off. any suggestions?
Nov 12, 2008 | Simplex Kaba Ilco Unican 1000 keyless...
Simplex Kaba Ilco Unican  1000 keyless lock  Logo
421 people viewed this question
Top Simplex Locks & Locksmithing Experts
JonSnell Electronic
JonSnell Electronic
Chris Walker
Chris Walker
Are you a Simplex Lock and Locksmithing Expert? Answer questions, earn points and help others
