Adobe Acrobat 7.0 Professional Logo
Posted on Dec 07, 2010
My Acrobat 7 Professional which is installed on Windows 7 Pro platform is gving me the following error message, "Your computer's configuration appears to have changed since the time this product was activated. To continue using this product, please click OK to activate it again for your new system configuration, or click Cancel to exit." Even if I activate it again the result is the same. I have removed and reinstalled the application but the same error message appears. Could you please help.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 21, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1291
Points
Adobe acrobat x pro configuration error 16
you need to uninstall and re-install before install download it again from main site again it will work.
Adobe Acrobat 7.0 Pro Error
Adobe has disabled the activation server for CS2 products, including Acrobat 7, because of a technical issue. These products were released more than seven years ago, do not run on many modern operating systems, and are no longer supported.
Download the New Copy of Acrobat and activate it with the new serial Number .
Click this Link CS2 downloads
2helpful
2answers
An error has been detected with a required application library and the product cannot continue. Please reinstall the application.
Basically lot of people are getting errors with Acrobat 7 and older versions as Adobe has disabled the activation server for CS2 products, including Acrobat 7, because of a technical issue.
Go to the Click here for the Link to Download Acrobat
Download the New Copy of Acrobat and Activate it with the new Serial No, however you need to un install the old copy from your computer
Dear Sir I am installaing WIn Xp Professional 64 bit on Intel motherbaord DH 61 WW with 8 GB corsair ram and after the boot hardaware error occurs and its ask to check the hardware or viruses...
The motherboard has nothing to do with your problem. Its your processor it has to be a 64 bit processor. If you don't during the installation you will get an hardware error. Your windows 7 must of been a 32bit or aka 86x platform. So put windows 7 back on (recommended) or try windows xp pro 32bit
Anyone else had the following problem, and any solution? I am Running Windows 7 Ultimate, 64 Bit.\, totally up to date system, no ram issues, etc. Trying to install Panda Antivirus Pro 2010. It...
your operating system is running in 64bit platform... but the panda anti virus setup you are trying to install is supported only for 32bit operating systems only...
you can install the anti virus on any 32bit operating system....
there is no problem with the setup or with your computer .. it is just that anti virus setup you have does not support 64bit operating system
I just installed acrobat pro 7.0 on our new computer and when I try to open any document it freezes and says it's not responding. I've used it on our old computer with no problems. I did the full...
Restart your computer and try again! If not acrobat pro 7.0 is not compitable with the operating system on the new computer.
If the O/S on your neww PC is vista plaese read the link below.
http://vistalounge.com/windows-vista/adobe-acrobat-7-and-windows-vista
All the best!
Brand new computer and i did not install the adobe it came with the computer Vista basic and i get the 1311 error message when i try to run adobe computer 1 day old !
no big problm if u comp is new r old...
When you try to install Adobe Acrobat 6, 7, 8, or 3D on Windows, the installer returns the error message "Error [1311, 1335 or 2350]. Source file not found: [drive name]:\ Adobe Acrobat [version]\data1.cab. Verify that the file exists and that you can access it." If you click Retry, the installer returns the error message "Cannot find the file Adobe Acrobat [version]\data1.cab."
Solution Perform one or more of the following solutions:
Solution 1: Check the Acrobat CD-ROM.
Make sure that the CD-ROM from which you are installing is free of dirt and debris. If necessary, clean the CD-ROM with a soft, lint-free cloth.
Solution 2: Temporarily disable anti-virus software, and then install Acrobat.
For instructions, see the documentation for the anti-virus software or contact the manufacturer.
Solution 3: Extract the compressed installation files, and then install Acrobat.
  1. Right-click the folder and choose Extract All.
  2. Follow the on-screen instructions.
  3. To install Acrobat, double-click the Setup.exe file located in the folder that contains the extracted files.
Solution 4: Uninstall the CD-ROM drive and let Windows redetect it, and then install Acrobat.
  1. Right-click My Computer and choose Properties.
  2. Click the Hardware tab, and then click Device Manager.
  3. Expand the DVD/CD-ROM drives section.
  4. Right-click each device listed under DVD/CD-ROM drives and choose Uninstall. Click OK to confirm.
  5. Close Device Manager and restart the computer.
  6. After Windows redetects the DVD/CD-ROM drive(s), insert the Acrobat CD into the CD-ROM drive and install Acrobat.
Solution 5: Install Acrobat from the desktop.
  1. Insert the Acrobat CD into the CD-ROM drive.
  2. Copy the Acrobat folder from the Acrobat CD to the Desktop.
  3. Double-click setup.exe in the Acrobat folder on the Desktop, and then follow the on-screen instructions to complete installation.
Additional Information Errors 1311, 1335, and 2350 occur when the Acrobat installer is unable to access the necessary files from the CD-ROM drive. These same errors may also occur if antivirus software interferes with an installation or if the installation files are compressed.
thank u sir,, if u feel i helped u, then plz vote/rate me with good marks..thank u!!
Top Adobe Computers & Internet Experts
k24674
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
