Question about Archos 504 500870 Digital Media Player
Archos 504 brand new keeps shutting down Why? how does one fix it?
Posted by porkyspiglet on
5 Related Answers
Anonymous
SOURCE: can't get out of recovery code 2 on archos 504
Try my suggestion to "recovery code 4" error. It should work, too.
Posted on Dec 19, 2007
Anonymous
SOURCE: Archos 504 RESET button
i press the little gold bump. it worked. thank you so much
Posted on Feb 13, 2008
informatica
Greg Cann
  • 1114 Answers
Hi - You can download the manual from the link underlined in blue below:
Archos 504
Se page 7:
Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Jul 21, 2008
nickyj44245
SOURCE: Archos 504 160gb wont start
Take the battery off, and to the left of the battery connetion tabs is a small gold button, push and hold for 10 seconds. It should start up after doing this.
Posted on Dec 03, 2008
Anonymous
SOURCE: My Archos 504 will not power up.
Press the Reset button on the inside of the unit with the battery removed. This should solve the Problem. If not you may need to send it in.
Reset button is located under the battery. So remove the battery and loo for the button at the end of the archos where the battery pins make contact. To the right of those and half way down between the pins and the case of the hard drive will be a gold round looking circuit. this is the reset. Press it and off you go.
Thanks,
Ed
Posted on Mar 02, 2009
Archos 504 comes on when plugged in briefly but no charge
I had the exact same problem, I looked a bit on the net and I found the answer. What you have to do is push the reset button when your archos isn't plugged on. The reset button is located behind the battery ( you'll have to the remove the battery ) near the pins that connects the archos to its battery. It looks like a gold circle and if you push it you'll see it's a button. After pushing the reset button try to put the battery on back again and replug your archos, it should work normally now.
Good luck !
May 12, 2009 | Archos 504 500870 Digital Media Player
I own an Archos 504, i purhcased today a DVR Station GEN 5, the box states compatibility with the 405 and 605, is it compatibble with the 504 too? could you confirm this please before i open the box many...
yes it is compatible but the remote wont work for Archos 504. also, u'll require saddle for 504(usually comes as part of package). dont try to put your archos on the dock without a saddle.
Mar 18, 2008 | Archos 504 500870 Digital Media Player
Archos 504 Powers Up and Immediately Shuts Down!
bad battery bad ones will show charged but cant push out full violts pc needs ok buy new one 1st
Jan 28, 2008 | Archos 504 500870 Digital Media Player
Archos 504
try resetting it via the button under the battery cover next to the hard drive, and if not, connect it to your pc, and format it as quick as poss.
Dec 09, 2007 | Archos 504 500870 Digital Media Player
Recovery code 4 on archos 504
I had the same problem and manage to solve it. You need to do the following
a. go to Archos website and download latest firmware and save on your pc
b. turn on 504 and select repair - unit not connected to pc
c. connect 504 to pc and wait until pc recognise it
d. copy firmware from pc and past to 504 root directory.
e. press done on 504. that should work. I've spent the best part of 10 hours looking for a solution to the dreaded recovery code 4. The problem is a corrupt os. I hope you're as lucky as me.
I still have a problem with mine though...a screen that blink constantly.
Nov 01, 2007 | Archos 504 500870 Digital Media Player
Archos 504 charging
just for mat it . its the best way to recover it
Sep 17, 2007 | Archos 504 500870 Digital Media Player
Archos 504
I had a similar problem remove the battery and push the gold coloured reset button. It worked on mine, You don't lose any info doing this. I got the advice from the Archos support phone number CC
Aug 19, 2007 | Archos 504 500870 Digital Media Player
Archos 504 500870 Digital Media Player Logo
90 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
Harrie
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
