Troubleshoot a Compaq Wireless Network Card
step 1
Open the Compaq's "Start" menu and type "Device Manager" in the "Search" box. Click the "Device Manager" icon.
step 2
Scroll down to the "Network Adapters" heading and click the plus sign to expand the list of attached network adapters. Right-click the name of your computer's wireless network card and choose "Uninstall." Follow the uninstall prompts on the screen.
step 3
Close the "Device Manager" window and return to the "Start" menu. Click "Restart" and wait for the operating system to boot up again. Follow the "Found New Hardware" prompt that loads on the screen to reinstall the network card.
step 4
Return to the "Device Manager" window and right-click the network card's entry again. Choose "Update Device Driver." Follow the prompts to install the latest driver.
step 5
Check the left side of your Compaq computer if you are using a laptop to see if it has a wireless network switch. Push the switch over to the "On" setting if it is set to "Off."
step 6
Open the "Start" menu and click "Network." Select the "Network and Sharing Center" icon at the top of the window.
step 7
Click the red "X" icon to have Windows automatically search for the problem. Follow the prompts to diagnose and resolve the network connection issue.
step 8
Double-click the networking icon in the system tray at the lower, right corner of the screen and click the name of the network you need to connect to if you are using Windows 7. In Windows Vista, instead click "Connect To" in the "Start" menu and click the name of the network.
Setup home Wireless Network
If you need more help come back.Post /
thumbs / testimonial are
welcome!
In order for the wireless computer to connect to the router wirelessly, the router and the computer's wireless settings should be the same. Before trying to connect your wireless adapter to a Linksys wireless router, please know the following: SSID or Network Name, Wireless Security and/or Network Key.
Connecting to Wireless Networks Using XP's Wireless Zero Configuration
To connect to the wireless network using Windows Vista, click here.
Follow these steps to connect to your wireless network using XP's Wireless Zero Configuration.
Step 1: Right-click the Wireless Network Connection icon at the bottom-right of the screen and select View Available Wireless Networks.
NOTE: If Wireless Zero Configuration (WZC) is disabled or other wireless network monitor is running, the Wireless Network Connection will not appear at the bottom-right corner. To enable WZC on the computer, contact Microsoft or consult the computer manufacturer.
Step 2:
Select your wireless network
Step 1:
Launch the Linksys Wireless Manager. To learn how to access the Linksys Wireless Manager, click here.
Step 2:
In the Connect to a Wireless Network screen, locate the name of your wireless network in the list.
NOTE: If your wireless network is not in the list, click here to learn How to Connect to a Hidden Wireless Network. If your wireless network supports Wi-Fi Protected Setup , click here to learn How to Connect Using Wi-Fi Protected Setup.
Step 3:
Select your network. Then click Connect.
Step 4:
If the wireless network uses wireless security, enter the security key or network. Then click Next.
Step 5:
The Checking Connection screen appears while the Wireless Manager establishes the wireless connection. When it is finished, click Next to continue.
Step 6:
The Connected to Your Network screen appears. If you want the Wireless Manager to remember your network settings select Remember this network. Click Finish to exit the Wireless Manager.
NOTE: Saving a network's settings will make it easier to reconnect to the network.
Step 1:
Step 2:
Step 3:
