Question about Nokia N72 Cellular Phone
I have Nokia N 72. whenever I connect with cable to USB port it popups a massage "USB device Not recognised". Before Few Months , it was working properly. and other mobiles and USB devices are getting recognised under this and every port. please help me out.
Posted by pranitjadhav on
geetharani s
    President:
  • 782 Answers
Sir plz install the n72 pc suit to the computer.and then connect the data cable from phone to the pc to transfer the files [or] change the data cable for proper connectivity from phone to the pc.................
Posted on Dec 07, 2010
2 TB G-Raid External Drive connected with Firewire cable is not recognised after Reboot my PC
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Mar 16, 2012 | Acomdata USB 2.0 2 TB External Hard Disk...
When I connect my wd passport, this massage appears "usb not device recognized". although the cable is working with other devices and the wd passport is also working on other computers (not my...
there is NO problem on you external hard drive..the problem is in your own computer USB port..try to uninstall the driver of your usb port.then try it again.
Jun 15, 2011 | Western Digital My Passport Essential 160...
USB DEVICE NOT RECOGNISED
Be sure the problem is not from the cable, by confirming that the cable works well with another phone. If it works well on another phone, try another USB cable.
If it shows the same message, then connect the cable to a different port on the PC.
If the message still shows plug it into another system.
If it works on the other system, then the device was not recognised on the initial system because USB ports must have been faulty.
You would have to un - install, then re - install the USB drivers.
Do this by clicking 'My Computer', then 'Device Manager'. Select 'USB Ports'. Right click it and select Re - install.
But if it still does not work on another system, and then your phone's USB port might need to be changed.
Hope that helped?
Success.
May 12, 2011 | Nokia N95 Cellular Phone
My Nokia N72 Not Connected To Pc , i download the last PC suit and cable connectivity driver but i am not successfull . when i shake cable a message apear and ( "USB Decive Not Recognized...
hi there!
with that error message "USB Decive Not Recognized", it means that there might be something wrong with the usb cable you're using or the usb port on your pc. try connecting it to a different usb port. if its the same thing, try using another usb cable.
Apr 08, 2011 | Nokia N72 Cellular Phone
Hi i have an everio gz-mg 135 and when i connect it to my pc to back up files the message "usb device not recognised. One of the usb devices attached has malfunctioned. Windows does not recognise...
- Make sure you have been installed JVC driver on your PC - If your PC has multi ports USB, just try other ports to make connection - check your firewire, it may be malfunctioned . Try other USB cables
Jan 16, 2011 | JVC Everio GZ-MG130 Camcorder
When i connect the external hdd to my lapto, it is not getting recognised.It does not gets displayed as an drive under " my computer"
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Nov 17, 2010 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Iwant to connect nokia 3600 to lap top to be able to download photographs
There is two main ways that you can transfer photographs to your laptop;
  • USB 2.0 Full Speed for rapid music transfer Nokia Connectivity Cable CA-101 - High-speed data transfer
    This micro USB cable provides high-speed USB 2.0 data transfer rates, and enables charging your compatible device or enhancement from a laptop or PC USB port.
  • Bluetooth 2.0 with stereo audio profiles for wireless music listening and control.
Jan 20, 2010 | Nokia 3600 slide Cellular Phone
Nokia 3110 classic usb device malfunctioned
Please try connecting your phone to a different USB port other than the one which you use normally.
If the issue is the same then try connecting it to another PC if you still face the problem then it is a hardware issue.Either your phone or the USB cable is gone bad.So replace the USB cable first with a new one and then try connecting.If the issue is till the same then it is your phone and you will have to get it repaired or get it replaced if it is under warranty.
Feb 10, 2009 | Nokia 3230
I have LG KP199 mobile , when i connect to PC massage display on pc as USB not recognise OR not recommanded.WHY?
Connect the phone at the rear (Back) side USB port. This will solve your problem.
Note: Do not use any extension cable for this. Connect using the company cable only
Dec 15, 2008 | LG KP200 Cellular Phone
Nokia N72 Cellular Phone Logo
131 people viewed this question
Top Nokia Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Zaid Anarwala
Zaid Anarwala
SANTHOSH
