Question about Mitsubishi WS-55511 55" Rear Projection Television
I NEED THE ELECTRICAL DIAGRAM OF THE MITSUBISHI WS 55511
Posted by antolne on
SD Tech
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
WHAT IS PROBLEM WITH SET AND WHAT DO YOU NEED KNOW?
SD TECH
Posted on Dec 07, 2010
1 Related Answer
SD Tech
SD Tech
  • 14553 Answers
SOURCE: WS-55511 Mitsubishi projection TV is stuck on INPUT 4.
This model was first made in 2002 and is a V21 Mitsubishi chassis.
I presume the front input or device button does not do anything.
This (if it is a WS-55511) has an option code that can be accessed. It will reset everything back to the condition the set was in when it was new in the box; once executed you will have to put it in the cable band and autoprogram it----email me if you need instructions for this and I will give them to you.
[email protected]
If this was helpful I would appreciate a vote from you.
Posted on Aug 12, 2009
Tip
Mitsubishi WS-73711 Manual Download
Download Mitsubishi WS-73711 HDTV Manual
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Have you misplaced your Mitsubishi WS-73711 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-73711 HDTV Users Guide?
Follow this link (& click FREE) to download a pdf version of the Mitsubishi WS-73711 HDTV operations manual.
I hope that helps.
__________________________________________
Reset Mitsubishi WS-73711 VChip Password
Bypass Mitsubishi WS-73711 Front Lock
on May 05, 2010 | Televison & Video
How much does the tv weight in us lbs
Model Weight Height Width Depth
WS-48511 175.5 lbs. 49" 44.5" 24"
WS-55511 238 lbs. 50.3" 50.6" 28"
WS-55711 266 lbs. 50.3" 50" 28"
WS-65511 337 lbs. 61.9" 59" 28.1"
WS-65611 336.5 lbs 61.9" 59" 28.1"
WS-65711 356 lbs 61.6" 58.2" 28"
WS-65712 251 lbs. 61.7" 58.2" 28.4"
WS-73711 410 lbs 65.7" 65.2" 30"
WS-B55 238 lbs. 50.3" 50.6" 28"
Oct 20, 2012 | Mitsubishi WS-55511 55" Rear Projection...
MY MITSUBISHU WS 55511 WHEN POWER TURNED ON WILL
I have the same set doing the same thing. I will replace IC and fuses to see if that will fix it.
Jan 05, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Tip
Mitsubishi WS-48511 Manual Download
Download Mitsubishi WS-48511 HDTV Manual
Have you misplaced your Mitsubishi WS-48511 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-48511 HDTV Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
Reset Mitsubishi WS-48511 VChip Password
Bypass Mitsubishi WS-48511 Front Lock
on May 03, 2010 | Televison & Video
Tip
Bypass Mitsubishi HDTV Lock
Bypass Mitsubishi HDTV Front Button Lock
Would you like to bypass, defeat or reset your Mitsubishi HDTV Front Button lock?
If you have misplaced your remote control, and have engaged the Mitsubishi HDTV Front Button Lock, you can bypass the front button lock by pressing and holding the MENU button on the front panel for more than 8 seconds.
I hope that helps.
Reset Mitsubishi HDTV VChip Password
Mitsubishi Projection HDTV Manual Download
on Apr 30, 2010 | Mitsubishi WS-55511 55" Rear Projection...
WS-55511 Mitsubishi projection TV is stuck on input 4, remote will not work at all. Any suggestions?
[email protected]
Aug 12, 2009 | Televison & Video
Tip
Mitsubishi WS-55511 Manual Download
Download Mitsubishi WS-55511 HDTV Manual
Have you misplaced your Mitsubishi WS-55511 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-55511 HDTV Users Guide?
I hope that helps.
Bypass Mitsubishi HDTV Front Panel Lock
on Apr 30, 2010 | Televison & Video
Tip
Bypass or Reset Mitsubishi HDTV V-Chip Password Lock
Would you like to bypass, defeat or reset your Mitsubishi HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password.
When your passcode is requested, press the number 9 and the QV button on the original TV remote control at the same time. This process temporarily unlocks your TV.
When you enter the V-Chip Lock menu, pressing the number 9 and the QV button on the original TV remote control at the same time will delete your old password and prompt you to enter a new passcode. Pressing HOME at this time will cancel the entire passcode.
I hope that helps.
Tip
Bypass Mitsubishi HDTV VChip Password
I hope that helps.
Tip
I hope that helps.
Mitsubishi WS-55511 55" Rear Projection Television Logo
52 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
