Televison & Video Logo
Posted on Dec 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am trying to hook up a ps3 to a lg tv at Marriott in Napa ca. The TV is an LG 37LC5DC and is ran by a LodgeNet remote. The TV has two HDMI inputs in the rear, but when I try to change the input via the TV side buttons, the TV says AUX Input Not Available. How do I hook up the ps3?
Anonymous
Level 3:
Master:
  • Master 691 Answers
  • Posted on Dec 07, 2010
Anonymous
Master
Level 3:
Master:
Answers
691
Questions
Helped
126527
Points
1740
They have it set so you can't, the hotel would have to OK
Joe Maestro
Level 2:
Sergeant:
  • Expert 181 Answers
  • Posted on Jul 20, 2011
 Joe Maestro
Expert
Level 2:
Sergeant:
Answers
181
Questions
0
Helped
64560
Points
563
There should be a box called a Jack Pack near the TV; it could either be a standalone unit or integrated into the furniture. Plug in your decide using those ports; the TV should automatically detect the device and switch over.
2answers
How do I hook-up Netflix through a Sony Blu-Ray player and a LG television
If your Sony Blu-Ray player and LG TV are recent models, each should have an HDMI cable connection. HDMI is an method to connect your digital video and audio devices with just a single combined cable. In the case of your LG TV, using an HDMI cable will allow you to send the HD video signal to your TV's screen, and allow you to hear the sound through the TV's speakers.
Your LG TV may have multiple HDMI connectors, to allow other devices to send signals to your TV, such as a cable box or satellite box or digital video recorder (DVR). Your Sony Blu-Ray player will usually have just a single HDMI connector.
Purchase an HDMI cable from your local electronics store. There are different versions of the HDMI specification, and you should get a cable that you can verify is certified for the HDMI version 1.4 specification.
Plug one end of the HDMI cable into the Blu-Ray player, and the other end into one of the HDMI connectors on the TV, noting which one you selected.
When you turn on your Sony Blu-Ray and your LG TV, you should use the remote for the LG TV to select the input source. Your LG remote should allow you to select the HDMI input connector you used, at which point you should see the display of a DVD playing on the Blu-Ray player. If you cannot hear the sound, use the LG remote to increase the TV volume.
Mar 02, 2015 • Netflix
2answers
I have a Emerson Tv that doesn't have a HDMI input is there a converter I can buy to hook my bp145 LG Blue-ray up
There is an adapter that goes from HDMI to DVI, There is even a cord that is HDMI on one end and DVI on the other.
A lot of TVs have the VGA PC connection on the back, not sure if your model has it, but you need DVI specifically and its not as common on TVs.
I bought a bp145 dvd player and when it is hooked up to my lg 32lc5dl tv I get sound but no picture it says no signal how do I fix this
Verify what input source your LG television is on. Using buttons on the tv or the remote you can change the input source. The input you want to choose needs to match the connection type of the dvd player. For example if you are connected using HDMI, than you will want to choose HDMI from the input source menu. There may be more than one HDMI so be sure to try each one.
Program a tv remote
Try these One For All Universal remote LG codes: 0056,0030, 0178, 0056, 0019, 0032, 0001, 0017,0178, 1265
Can i connect my ps3 to lcd lg tv, via hdmi cable?
You should be able to as long as your TV has an HDMI input. The PS3 supports a bunch of resolutions, and should auto-detect the highest resolution your TV is capable of once connected by HDMI.
4helpful
I have a LG LHB335 Blu-Ray home theater system, & a LG TV I can get Full surround sound when the blu-ray is play a DVD but not when just watching Reg TV. I use a HDMI, should I hook up sonething else ?...
LG documentation states:
When you use SIMPLINK function, you have to
connect to the OPTICAL IN 1 jack to enjoy TV
sound to your speaker system.
Basically you need to have the Audio go from TV to receiver and setup receiver to that Input to output surround sound to all speakers.
If you have a cable box or satellite receiver, hook that output into the receivers input and that should work.
My setup is DirectTv HDMI output goes into the LG Home Theater HDMI Input 1, and LG goes HDMI output into the TV HDMI input 1.
so to watch DirectTV, I switch LG Home theater to HDMI Input 1. and TV is on HDMI input 1 (to view LG HDMI output from DriectTV, Blu-Ray, Vudu, etc.)
2helpful
2answers
How would i know if my HDMI ports are working or not?? Tried to connect a PS3 to it but nothing. Thought it may have been the cable so checked someones that i know is working and still nothing. Checked...
As you already checked PS3 and HDMI cable,
select HDMI input in TV and connect PS3 via HDMI cable. TV should show PS3 picture.
And if still no joy then HDMI input port in TV is bad and need to replace input board/ main board.
Cant tune ps3 to lg tv
Be sure you have the HDMI cable in the correct slot for the input channel you are trying to connect. Try another input channel like HDMI 2, 3, or 4 depending on how many channels you have. If you have another TV with HDMI, try plugging it in the other one to see if it is a problem with your TV or the PS3.
Change HD settings on lg plasma tv without remote
u need tv remote, with that u can go to the options for ur tv and enable the hdmi allowing ur ps3 to come onto ur tv.
Can't play PS3 on LG 42LC7D tv
use hdmi cable from ps3 to rear of tv (you should have hdmi 1 & hdmi 2)then ppress input on remote until you get hdmi 1 or 2 on screen walaa
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
