Question about HP LaserJet 4500 Printer
I just purchased my HP 4500 printer and began to install it. I see an error (!) symbol and I believe German writing. I need to remove that symbol and change the language to English.
Posted by abstract750 on
Seeker5211
    Genius:
  • 1,089 Answers
Selecting the display language
To change the display language on the printer control panel, do the
following:
1 Press and hold [SELECT] on the printer control panel while pressing
the standby button (power switch). Continue holding [SELECT] until
the control panel displays
SELECT LANGUAGE (in English), and then release the [SELECT] key.
2 When the control panel displays LANGUAGE=ENGLISH *, press
[VALUE] repeatedly until your language choice appears.
3 Press [SELECT] to save your language choice. An asterisk appears
next to the selected language. Then press [GO].
4 After the printer warms up, the control panel displays READY in the
selected language.
Note
If the control panel does not display the message in the language you
selected, press the printer standby button and repeat the instructions for
changing the display language.
Posted on Dec 07, 2010
Directions for inserting ink cartridges
Replacing the Ink Cartridges for Deskjet 6940 and 6980 ...
support.hp.com/us-en/document/c00569593
Selecting the correct print cartridge, and removing and installing print cartridges. ... Damage may occur to the HP Deskjet printer if the print cartridges are not docked ...print cartridges, or continue to the sections below for detailed instructions.
Replacing a Cartridge - HP Deskjet 2540 All-in-One Printer
www8.hp.com/.../printers.../replace-ink...toner/.../replac...
Hewlett?PackardLearn how to replace a cartridge in the HP Deskjet 2540 All-in-One printer.
Replacing a Cartridge - HP Envy 4500 e-All-in-One Printer ...
? 3:56
https://www.youtube.com/watch?v=oJVYTXaI6e4
Jul 11, 2014 - Uploaded by HP Printer Support
The HP Instant Ink program is only available in the following countries - United ... ... Replacing a Cartridge - HP Envy 4500 e-All-in-One Printer ... HP ENVY 4500 WIRELESS SCANNERCOPIER REVIEW - Duration: 13:52.
Jan 16, 2016 | HP Office Equipment & Supplies
How do I install my printer
You need to install the driver on your computer or laptop. Go to the manufacturer's website and there should be a link for the model you have purchased to download.
Oct 11, 2014 | HP Office Equipment & Supplies
I cannot put the paper all the way in the paper tray,hp envy 4500
I've never HAD nor FIXED your model, but have fixed other HPs with different problems before. Re: your hp envy 4500 model printer: I researched a little, finding this:
great product, January 12, 2014
Love the printer and it's performing great. I was thinking of giving this nice printer four 1/2 stars, because the direction should have emphasized more clearly that the paper holding tray must be pushed all the way back in to the printer not just the paper. So when you think the tray is all the way in give it another push. because one can not continue with any of the installations. It would not be fair to the product itself, to write negatively.
Found the above here: Page 4: http://www.amazon.com/HP-Envy-4500-Wireless-Printer/product-reviews/B00CIDQ470?pageNumber=4 or read more here about the paper tray:
http://h30434.www3.hp.com/t5/Printer-All-in-One-Install-Setup/HOW-TO-PULL-OUT-THE-PAPER-TRAY-ON-ENVY-e4500/td-p/3071717 It looks like the Paper Tray is persnickety on this model... Hope this leads you to a solution. {P.S. Recently when my almost 5 yr. old HP printer died-for good- I bought a "Brother" because I found they give you toll-free Tech Service "for the life of the printer"... and that's what I like!}
May 29, 2014 | HP Officejet Pro L7680 All-In-One Printer
How can I get my HP Laser Jet 1320 printer to get unlocked from red flashing light that prevents prnter from working? When I printed a three page e-mail report, after the first three were printed, an...
I had similar problems with my Printer also. Believe me, it can happen if the printer driver is corrupted or if your windows installation or windows update caused some conflict issues with the printer. I got online help from TheBestPcDoctors. If you need, you can contact them or call them
www.thebestpcdoctor.com or via 877-407-9229
Sep 27, 2011 | HP LaserJet 1320n Printer
I purchased the HP officejet 4500 all in one. The message "fatal error" comes up while installing. I have business Vista. What do I do? Thanks. Lisa
some errors usually include a four-digit numbered code. if there is, please let me know. I also need to know the exact error message. where do you see the error message? on the computer or printer? PLEASE TAKE NOTE THE EXACT ERROR MESSAGE AND LET ME KNOW.
for the mean time, you can use the printer without troubleshooting the error by just installing the basic driver. the product will still print as usual however the product might not have its full functionality. steps in installing the basic driver: restart the HP software installation then select the "express" or "minimal" installation option instead of the "full recommended" installation option. Then follow the on-screen instruction to complete the installation.
Jul 26, 2011 | Office Equipment & Supplies
Just stoped printing;print cartridge problem
Remove print catrige and clean it with cotton cloth then refix it.
May 19, 2009 | HP OfficeJet 6210 All-In-One InkJet...
HP Color LaserJet 4500 Printer
Here is your problem. Hope that this helps you.
54.1 PRINTER ERROR
Description:
Indicates that an internal power failure has
occurred.
Action:
1. Turn the printer off, and then turn the printer
back on.
2. Replace the high-voltage power supply.
3. Check the fuser to ensure jams have not
occurred.
Caution When clearing jams, the
thermistor can be damaged
causing this error.
4. Make sure there is not a fluctuation in the
power supply to the printer. Check that the
electrical specifications (see Chapter 1) are
met.
5. Replace the low-voltage power supply.
Apr 02, 2009 | HP Color LaserJet 4500 Printer
Error code 93:11
System Error: 93:11
Description: Unable to pressurize the IDS.
Corrective Action: Try the following:
Remove ALL the Ink Cartridges and reinstall them one by one in to the Printer.
Replace the Ink Cartridges.
Replace the APS Assembly.
If the System Error continues, replace the Ink Supply Tubes and Trailing Cable.
Dec 29, 2008 | HP Designjet 4500 Pass-Through Scanner
HP LaserJet 4500 Printer Logo
1,501 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
