Question about Broderbund PrintMaster Platinum 16
SOURCE: will Printmaster Platinum 16 run on windows 7 I
Printmaster Platinum 16 is not compatible with Vista or windows 7.
Posted on Oct 24, 2010
SOURCE: I WOULD LIKE TO CONVERT
If I was in your place I would use a direct connection if both computer's are connected to the internet ...and in the same default gateway ..its easy ..cause you can find the other computer into my network places folder..after you select the view workgroup computers task ...You will have to disable the firewall in both machines and after that you will have access on the other computer just like in my computer folder..and copy files...
If they are not on the same workgroup...than you can use a remote control program to transfer the files directly ..THis one will do the job ..,all you have to do is to install it on both machines ..open in the remote one ..and in yours..and get the ed and password offered by the program and connect to it ..after that you basically have ful access to it ..even tranfer files..
here is the program :http://www.teamviewer.com/index.aspx
If the machines are not connected to the internet than the only way is to use a large memory stick or an external hard drive ...or just get the hard drive from the one you need the files and connect it temporary to the other one ..and you will find its partition in My computer ..after that just copy paste the files in the other partition from the computer you intend to use..
Posted on Oct 25, 2010
SOURCE: IS THERE A PATCH TO MAKE PRINTMASTER PLATINUM 16
yes can be, just follow these steps:
Not compatible or not working well with windows 7?
Maybe, It doesn't work because the driver/application you installed is
for other versions of operating system. I am also using windows 7 like
you so don't you worry, You can still use your old installer/driver from
other versions of operating systems. Just remember that before
installing any program in a windows 7 Operating System Computer, Use
"troubleshoot compatibility". Right Click the Icon of your program
installer/application first, then choose "troubleshoot compatibility".
This will allow you to choose on what type operating system your program
will run. Just reply back if it still doesn't work.:D rate and vote
for me:))
Posted on Dec 06, 2010
SOURCE: Can I load Printmaster 16 on Windows 7?
Printmaster 16 will work with Vista and Windows 7, you need to run setup.exe as administrator.
Posted on Dec 12, 2010
SOURCE: How can I run PrintMaster 16 Platnum in Windows 7
Printmaster 16 Platinum is an older program and is compatible with XP and older versions of Windows.
First check which version of Windows 7 that you have. Click Start > Control Panel > System and Security > System. If your version title ends with x64, you will need to use an option that lets you run an older version of Windows. If you do not see x64 in the title, then the compatibility mode might work.
For the 32-bit OS, right click on the installer and choose Properties. In the Compatibility tab, check the box for always run in the compatibility mode and select an older version of Windows. Apply the changes and click OK. Then right click again and choose Run as Administrator. You may need to repeat this to run the software as well. This is not guaranteed to work in Windows 7 32-bit.
The alternative is to run an older version of Windows. This could be on a second computer, a dual boot computer or a virtual computer (if your hardware supports the feature). Most of these methods require licensed version of the older Windows OS. If you have Windows 7 Pro or Ultimate or upgrade to them, you can run a virtual XP OS for free. Download Virtual PC and XP mode from Microsoft. Then install the Printmaster program in XP as if this is the only OS. (Other virtual computer programs are Parallels and VMWare.)
The only other option is to upgrade to a version of Printmaster that is Win7 compatible. One option is Printmaster 2012 Platinum available here: http://www.broderbund.com/p-273-printmaster-2012-platinum.aspx .
I hope this helps.
Posted on Dec 11, 2011
Mar 02, 2018 | Broderbund PrintMaster Gold 16 for PC
Apr 05, 2012 | Broderbund PrintMaster Platinum 16
Dec 10, 2011 | Broderbund PrintMaster Platinum 16
Jul 19, 2017 | Broderbund PrintMaster Platinum 16
Dec 20, 2010 | Broderbund PrintMaster Platinum 16
Nov 08, 2010 | Broderbund PrintMaster Platinum 16
Oct 24, 2010 | Broderbund PrintMaster Platinum 16
May 31, 2010 | Broderbund PrintMaster Platinum 16
Mar 05, 2010 | Broderbund PrintMaster Platinum 16
Jan 10, 2010 | Broderbund PrintMaster Platinum 16
167 people viewed this question
