Hi there, you'll need to open the keboard and check for the keys that has a missing mechanism on it. It usually is a stopper to prevent the keys from "sticking". You can use crazy glue or mighty bond to stick the broken parts together.
First disconnect the CPU with Monitor ,Keyboard and Mouse and re-connect.after that remove RAM and re-insert or check with another RAM if issue resolve if not then check that the Keboard Num lock is on/off or not if not then issue with your system if yes then your monitor is faulty might be EHT has been faulty.
For cpu check the VGA port and Operating system
Actually your keyboard is not getting connected, So first you
put your keyboard straight with the sensor & push the keboard sensor button which is botom of the keboard it will detect the keboard after that you can work.
