Question about Broderbund PrintMaster Gold Version 18
I am trying to print business cards using printmaster gold 18. I have an Avery stock which is not in the stock list. I have entered the measurements of the cards into the custom paper wizard but the cards will not print out to these measurements. What am I doing wrong?
Posted by bcaldoc on
  • 7,733 Answers
What is your Printer model?
Posted on Dec 06, 2010
Can I add a watermark to a flyer using Printmaster Gold 18?
I am trying to install a watermark to a document with print master gold 18. I'm having absolutely no success whatsoever. Anyone withany suggestions
May 20, 2010 | Broderbund PrintMaster Gold Version 18
I am trying to print a greeting card!
ITS ALL DOWN TO YOUR PRINT PREFERENCES.
NOT SURE YOU PROG, SOME ARE EASY TO SETUP/OTHERS A RIGHT PAIN.
TAKE TIME CLICKING TEMPLATES AND SIZES?
Nov 15, 2009 | Broderbund PrintMaster Platinum 16
Avery label printing alignment issues. Please Help!
you may need to use some free software that is available for 10.4 and 10.5 users. produced by avery it is the DESIGN PRO available for download at http://www.avery.com/avery/en_us/Templates-&-Software/Software/Avery-DesignPro-for-Mac.htm
also available for PC
a bit awkward to learn, it does the advertised job
Jul 30, 2009 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
My business cards will not print from Printmaster Gold to HP 2410 Printer. Everything else prints except business cards. I get a box that indicates the are printer but nothing prints.
your cards are too thick .the printer wont actually move the card down to yhe printing heads. try placing just one sheet into the printer or/and go to setup and see if you can set the printer for thicker paper try user defined setting. no promises.
Apr 19, 2009 | Broderbund PrintMaster Gold 16 for PC
Printing on business card stock
goto avery website and download designpro for free it has all the templates for avery stationary
Mar 18, 2009 | Lexmark X6570 InkJet Printer
Printer problem
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 30, 2008 | Office Equipment & Supplies
Printmaster gold will not center print job
there should be a box to allow you to enter figures for the margins in the setup print job bottom margin etc put a figure in here usually centimetre or millimetres adjust untill your perfect print test page
Find the setup box ! might find it the drop down menu s at the top of the page good luck!
Dec 26, 2008 | Broderbund PrintMaster Gold 16 for PC
HP C4280 incorrect paper feed
Check your printer's capability.
Buy the card stock they recommend.
If all else fails, print on plain and take card stock to a copy shop and have them do it for you.
Walking there beats going nuts over stupid software or hardware problems
Dec 16, 2008 | HP PhotoSmart C4280 Laser Printer
I have Printmaster 10 and 17. On 10, I can print to the edges of the labels and others things, on 17 I can't. I know that I reconfigured 10 to do this, but it was years ago and I can't remember the step...
Custom Paper Wizard PrintMaster® 17 Gold and Platinum include a Custom Paper Wizard that allows you to add new or unsupported paper stock to PrintMaster® for printing labels, stickers, envelopes, half-fold greeting cards, note cards, business cards and postcards. The remainder of this note describes how to use the Custom Paper Wizard. Follow the procedure below to add a new or unsupported paper stock to PrintMaster® 17 Gold or Platinum using the Custom Paper Wizard.
NOTE: The options that appear in the Custom Paper Wizard vary depending on the project type for which you are creating new paper stock.
  1. In the PrintMaster® Design Workspace, click Tools from the menu bar, select Custom Paper Wizard and click New Custom Paper. The Custom Paper Wizard window will open.
  2. In the Select Stock Type: list box, select the appropriate project type (Label, Sticker, Business Card, Envelope, 1/2-Fold Greeting Card, Note Card or Postcard) and click Next.
  3. If creating a Label or Sticker paper stock, select the label type. An example of the selected label type will appear on the right.
  4. Click Next.
  5. In the screen that appears, select the similar stock type and enter the paper height, width and margins (if instructed to do so).
    NOTE: The Example box at the bottom of the Custom Paper Wizard window will explain what information is needed for the selected field (e.g., Paper Width, Left Margin, etc.) with both text and a diagram. The Example box on the left side of the Custom Paper Wizard window will show an example of the new paper stock as the fields are completed.
  6. Depending on the paper stock, the "Contains mid-page perforation" box may be active. If the paper stock that is added has a mid-page perforation, click once in the empty box to check it.
  7. Enter a Name for the new paper stock in the Name of stock: field and click Next. This name will identify the added stock type and will appear when creating a new project (e.g., Label, 1/2-Fold Greeting Card, etc.).
    NOTE: If adding a new paper stock for an Envelope project type, click Finish. A message will appear indicating that the new stock has been added. Click OK. The new envelope paper stock can be used when creating a new Envelope project.
  8. The next screen or screens that show will depend on the project type for which the new paper stock is added. Enter the needed information and click Finish. A message will appear stating that the new paper stock has been added.
  9. Click OK.
  10. To access the new paper stock, create a new project that uses the stock type (Label, 1/2-Fold Greeting Card, etc.) and select the name of the new stock entered in Step 7 (above) from the available stock list.
NOTE: If the paper stock that is added does not display in the list, click or go to Custom Paper Stock Does Not Display (Technical Note ID: 43399) for additional information.
Using the Custom Paper Wizard Tutorial
Consult the "Using the Custom Paper Wizard" tutorial in the Help Center of PrintMaster® 17 for additional information. The tutorial can be accessed in the manner shown below.
  1. Launch PrintMaster® 17.
  2. Click Help on the menu bar and select Help Center.
  3. Click the View or Print Tutorial icon (light bulb).
  4. Under Choose a Category, click Program Tutorials.
  5. Under Choose a Topic, click Using the Custom Paper Wizard
Oct 13, 2008 | Computers & Internet
Can't print any projects from Broderbound Printmaster Gold Version 18
Nobody uses that stuff anymore. Get LibreOffice, learn how to use it.
Apr 06, 2017 | Broderbund PrintMaster Gold Version 18
Broderbund PrintMaster Gold Version 18 Logo
123 people viewed this question
Top Broderbund Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
