Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
Posted on Dec 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The PKH3 FAK unit begins making an intermittent buzzing noise when it has been operating for about 10 mins. when the unit is turned off using the remote control, it continues making the noise for 10 mins or so. can you advise please? I have just bought the apartment where this air conditioner is installed. Thanks
R Subramaniyam Iyer
Level 3:
  • Master 2,133 Answers
  • Posted on Dec 07, 2010
R Subramaniyam Iyer
Master
Level 3:
Answers
2133
Questions
Helped
953285
Points
6173
As per your statement, it's understood, your unit is under gas leak. Hope there won't be cooling. Am I right?. Thanks.
True GDM-10 started making loud noise AFTER door was slammed after getting something inside; checked inside fan was running slow. Noise sound like something stuck in motor.
without knowing age of unit, I suggest replacing the motor. Sounds like the armature is worn the bearings and is moving inside the windings of the motor. I would do that first before moving forward with any other repairs.
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
BUZZING NOISE FROM MY HEAT PUMP
Take a look at this YouTube page that explains with good videos what are some of the common problems with heat pump noise. The one that seems dominant is the defrost cycle a heat pump goes thru when it melts ice off the evaporative coils. In defrost cycle, The compressor runs but the cooling fan does not, so you will hear a loud buzzing sound and the unit sounds like it is stalled...because only the compressor is running to generate heat to melt coil ice.
https://www.youtube.com/results?search_query=American+Standard+5000+Heat+Pump+makes+a+buzzing+noise
Defrost cycle noise video:
https://www.youtube.com/watch?v=wudLk0WoIVo
My Amana French door bottom refrigerator is making a buzzing noise. The noise is intermittent and seems to be getting worse. The ice maker seems to be work ok. Any suggestions on how I might fix it?
I USED TO HAVE THE SAME PROBLEM. CHECK TO MAKE SURE THE WATER LINE BEHIND THE UNIT IS NOT VIBRATING AGAINST IT, CAUSING THE NOISE. ALSO CHECK THE BOLTS ON THE BACK OF THE UNIT TO MAKE SURE THEY ARE TIGHT. THE HOSE WAS MY PROBLEM AND WHEN I FINALLY FIGURED IT OUT, I WAS SO RELIEVED NOT TO HEAR THAT BUZZING NOISE ANYMORE. AND I THOUGHT IT WAS ACTUALLY INSIDE THE FRIDGE!
No matter how much I clean the machine after it is turned on for 10 min or more it starts to buzz and make a static noise, any other suggestions?
The buzzing noise is not from dust in the air purifier, it's from the dust and pollutants in the air, it's now picking up. It should stop once the air is cleaned.
2helpful
The refrigerator keeps making a loud buzzing noise. It is not the ice maker filling up with water. The noise runs for about 5-10 seconds every hour or so.
Sounds like your starting components are bad on the compressor. If the freezer section begins to loose temp then this is probably the case. They will try to start the compressor and then it will kick off on its overload. However this will usually occur every 10-15 mins when they are completely toasted. Your compressor may be starting up part of the time and not starting the rest. Either way you will probably need new starting components on the compressor. You could also check to make sure your condenser fan motor is running (in the back of the ref behind the access panel) because this could cause the compressor to overheat but usually wont cause a buzzing noise.
Hope this helps _MJ_
Refridgerator is clicking on loudly then buzzing and sizzling
I bet the Iemaker arm has been turned on allowing th eicemaker to cycle every 10-15 mins when the icemaker calls for water it causes the water valve to open. with no water connected to the unit the valve buzzes loudly causing your noise. make sure the icemaker arm is in the up position thus turning the i/m off thanks peyton
Loud periodic buzzing
Are you sure this noise is not just the ice maker trying to cycle without water? If it is not turned off it will dry cycle every 15 min or so.
Top Mitsubishi Heating & Cooling Experts
 Mikey
Mikey
vince
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
