Question about Dacor Epicure 30" Double Wall Oven, Stainless Steel - E0230SCH Electric
How do I find the model number on a dacor double wall oven?
Posted by kgeorgens_on on
Vandre Soares
  • 148 Answers
The MODEL Series you already said in your question: EO230SCH
Check and see if it is this model:
Good Luck!
Posted on Dec 06, 2010
My Dacor oven keeps beeping and flashing PRB. How do I stop the beeping?
Most unwanted beeping on Dacor products are due to a bad touchpad... Use your model # and start looking for a replacement , by touchpad I mean a part something like this one: Dacor Touchpad 62678B
Jul 12, 2016 | Dacor Epicure 30" Double Wall Oven,...
Schematic wiring for epicure double oven eo230sch
Hi I found the schematic and a whole lot more here: http://www.msaworld.com/wp-content/uploads/sites/3/2014/07/Dacor-Technical-Manual-All-Products.pdf
Sep 19, 2014 | Dacor EO230SCH Discovery Epicure 30"...
Display panel works, but oven will not come on
I take it the oven will not heat. there is a safety thermo inside the grilles. it can be reset.. turn the power off at the breaker... remove the grille..inside of the door. then look inside the thermo is has two wires going to it and a red button in the middle.. push the red button down it will reset the thermo with a click... replace grille and restore power... hope it helps.. replace grille
Sep 19, 2009 | Dacor Epicure 30" Double Wall Oven,...
What size is the bottom element in a dacor model w305wc wall convection oven
I'm sure what you are asking. If you need an element, you can order it by your model number, which you have provided. We supply parts and you are welcome to call us at 9728590929 and we will be happy to assist you with your parts orders. We hope this helps!
Aug 14, 2009 | Dacor Epicure 30" Double Wall Oven,...
Dacor Double Oven
HI - I just had the same problem - repairman came and reset the breaker in the oven which "tripped" (even tho I havent used the lower oven in months).  Read posts here on other Dacor ovens which explain how to get to the reset switch to avoid having $150 in repair costs - I have not tried that myself tho but good luck!
Nov 08, 2008 | Dacor ECD230 Epicure Electric Double Oven
Dacor ECS230 Epicure Electric Double Oven
You probably tripped a safety thermostat in the back of each oven. If you turn off the breaker and find a way to pull the units out you could probably remove the rear panel and reset the thermostat by pushing in a button on the back of the open thermo. Some thermo's aren't resettable though so you'd have to buy a replacement.
Sep 22, 2008 | Dacor ECS230 Epicure Electric Double Oven
Ovens Logo
590 people viewed this question
Top Dacor Ovens Experts
Paul Bade
Vincent G
Vincent G
ray gallant
Are you a Dacor Oven Expert? Answer questions, earn points and help others
